I have upgraded my ubuntu to latest (18.04) on a dual boot HP Pavilion. The windows 10 partition has been unbootable for some time and now both partitions are unbootable. After the ubuntu upgrade completed, I had a message saying that my machine was in an unstable state with no instructions on what to do.
I tried to download new software, but was not able to because of a grub error message. I followed the instructions here to fix the error: What can I do to fix this error on grub-efi? (these instructions to be more specific: sudo apt-get purge grub* sudo apt-get install grub-efi sudo apt-get autoremove sudo update-grub)
The next time I restarted my computer I had a blue screen stating "Verification failed: (0X1A) Security Violation". After pressing enter I get a screen with "Shim UEFI Key management". I can then enter into a "Perform MOK management" screen with 3 options:
1) Continue boot 2) Enroll key from disk 3) Enroll hash from disk
Option 1, will display the security violation. Option 2, with every possible efi will not work., Option 3, with every possible efi such as grubx64.efi, shimx64.efi, mmx64.efi will fail to enroll the key.
Current state: I can't get GRUB or BIOS. Pressing F10 for example, should bring up BIOS on my machine, I see the text on the bottom saying BIOS menu, but no menu ever comes up. Pressing ESC will pause the startup, but there is no way to get out of that screen.
Things I have tried: 1) Updating BIOS by pressing windows + b, it goes through the process and then fails 2) Uploading BIOS to usb stick following instructions on HP website, no way to get to stick 3) Going through every single efi file with every option on MOK management screen
Not sure what to try next or if this something that can be recovered from.
EDIT: My goals right now 1) get to my data and back it up somehow 2) wipe out the system to start fresh in that order.
SOLVED: I was able to get into my BIOS by disconnecting the hard drive, booting up the system and pressing F10. Through the BIOS menu I could then disable Secure Boot. (Unfortunately, I have already reformatted my Linux partition). Hope this helps someone else who experiences the same issue.
