I have Sony's WH1000XM2 Bluetooth headphones. Unfortunately , with Ubuntu 16.04 LTS, the only connection procedure that works is as follows:
  1. Turn on the headphones.
  2. The headphones connect, but to all 3 audio profiles ("AudioSink, "Headset" and "Handsfree").
  3. Currently, no sound will be played.
  4. I then need to disconnect the "Headset" or "Handsfree" profile (works for both) in BlueMan and then reconnect only the "AudioSink" profile.
  5. Sometimes I also need to manually switch to A2DP, but most of the time I dont need to.
So my question is as follows:
  1. Can I somehow disable the profiles for this specific device?
  2. Can I maybe automate the process somehow?
thanks!
Fo me this helped to disable Handsfree profile
sudo vi /etc/bluetooth/main.conf
Add Disable=Handsfree under General
[General]
Disable=Handsfree
Maybe if you want to disable both you can specify like this Disable=Handsfree,Headset
Restart bluetooth
sudo systemctl restart bluetooth
