If you installed the wps office using snap, you need to connect the wps with removable-media connector, to verify it, run:
snap connections wps-office-multilang
output:
Interface Plug Slot Notes
alsa wps-office-multilang:alsa - -
cups-control wps-office-multilang:cups-control - -
desktop wps-office-multilang:desktop :desktop -
gsettings wps-office-multilang:gsettings :gsettings -
home wps-office-multilang:home :home -
opengl wps-office-multilang:opengl :opengl -
pulseaudio wps-office-multilang:pulseaudio :pulseaudio -
removable-media wps-office-multilang:removable-media - -
unity7 wps-office-multilang:unity7 :unity7 -
wayland wps-office-multilang:wayland :wayland -
x11 wps-office-multilang:x11 :x11 -
Check the Slot column of removable-media:
To connect removable-media with wps, run:
sudo snap list
Output:
Name Version Rev Tracking Publisher Notes
core 16-2.40 7396 stable canonical✓ core
heroku 3752 stable heroku✓ broken
slack 4.0.2 17 stable slack✓ classic
wps-office-multilang 10.1.0.6757-multilang 1 stable schmolli-christian -
Copy the exact name of wps (wps-office-multilang), and run:
sudo snap connect wps-office-multilang:removable-media
Output
The output needs to be blank. To check if it works, run:
Output:
removable-media wps-office-multilang:removable-media :removable-media manual
Now, the colum Slot of the line removable-media was changed.
Done.
If this does't work, check if your patition is NFTS, if so:
Try run on your partition:
ls -la /mnt/your-partition`
If all the files and folders is root:root, you need to inform your partition your user and group, but...
NTFS does't know what is a linux user or a linux group, so you need to mount your partition as permissions,users,auto,uid=<YOURID>,gid=<YOUR GROUP>,x-gvfs-show.
More details about it, check this link.
Warm regards, and good luck!
