I'm running Ubuntu 16.04 on a Dell XPS-15-9560. After installing Ubuntu, I followed this guide
https://github.com/rcasero/doc/wiki/Ubuntu-linux-on-Dell-XPS-15-(9560)
to configure my setup. In my first few months of using this machine, I was concerned about the low battery life and saw that the GPU was using a lot of power when I wasn't using it so I installed nvidia-prime in order to switch to the built in Intel graphics card. As far as I can tell everything worked fine then.
Now, I want to switch to the Nvidia GPU. However
sudo prime-select nvidia
produces output as though the card switched, but nvidia-settings won't start up, and rebooting brings back the Intel card.
Any ideas as to what I should do? I have looked at related posts, but I suspect that the people have further complexities in their setups.
EDIT
As requested by @Terrance, here is the output of
sudo lshw -C display
*-display UNCLAIMED
   description: 3D controller
   product: NVIDIA Corporation
   vendor: NVIDIA Corporation
   physical id: 0
   bus info: pci@0000:01:00.0
   version: a1
   width: 64 bits
   clock: 33MHz
   capabilities: pm msi pciexpress bus_master cap_list
   configuration: latency=0
   resources: memory:ec000000-ecffffff memory:c0000000-cfffffff memory:d0000000-d1ffffff ioport:e000(size=128) memory:ed000000-ed07ffff
*-display
   description: VGA compatible controller
   product: Intel Corporation
   vendor: Intel Corporation
   physical id: 2
   bus info: pci@0000:00:02.0
   version: 04
   width: 64 bits
   clock: 33MHz
   capabilities: pciexpress msi pm vga_controller bus_master cap_list rom
   configuration: driver=i915 latency=0
   resources: irq:130 memory:eb000000-ebffffff memory:80000000-8fffffff ioport:f000(size=64) memory:c0000-dffff
OK, I have appeared to solve the problem. For anyone else interested, I once again added the graphics driver ppa, and installed the nvidia-410 driver:
sudo add-apt-repository ppa:graphics-drivers/ppa
sudo apt-get update
sudo apt-get install nvidia-367
After doing this, you get a message asking you about disabling UEFI secure boot. Previously (in my "if it ain't broke don't fix it" mentality) I either avoided doing this, or didn't restart.
Anyway, say "Yes", give the system a password and REMEMBER IT! Then, reboot immediately, and you should get a screen asking you for letters of your password (or disabling Secure Boot) - I forget the order. Just continue cautiously, making sure you disable secure boot with the options presented to you, and choose to reboot.
After logging in, you should see that the NVidia graphics card is working as desired (e.g. in system information).
As for secure boot, is it important? See the discussion here.
