11
I read this article and want to avoid the complicated procedure to get Microsoft Teams running on Ubuntu 18.04.
https://techcommunity.microsoft.com/t5/Microsoft-Teams/TEAMS-and-LINUX-The-Future-is-Now/m-p/308382/highlight/true#M23115
Is there a simpler way?
Update 2021:
Follow the official docs: https://docs.microsoft.com/en-us/microsoftteams/get-clients#linux
guettli
  • 1,765
7 Answers7
12
On my Ubuntu 18.04.2 I installed it via the command :
sudo snap install teams-for-linux
( I did not understand the other answers completely
and the linked versions are older 0.2.1.
my install is 0.3 )
You can use the following electron client:
https://github.com/IsmaelMartinez/teams-for-linux
You can do desktop and screen sharing and all the other basics (mentions, video and audio call, integrations, opening meeting links, etc)
This is a continuation from the ivelkov project.
Install the debian package from the following repository!
https://github.com/sudhirnakka/teams-ubuntu-enhanced/releases
Sai Nikhil
  • 131
Edit: 2023
The Linux version of Microsoft Teams is no longer supported. It is recommnded to switch to the progressive web app (PWA) version, using Chrome, Chromium or Edge. See https://techcommunity.microsoft.com/t5/microsoft-teams-blog/microsoft-teams-progressive-web-app-now-available-on-linux/ba-p/3669846 for details.
Previously: Repository install
Installing from the official Microsoft Teams DEB repository has the advantage that Microsoft Teams will get automatically updated together with your other packages, as soon as Microsoft publishes a new release.
Here are four easy cut & paste installation steps to get about this:
1.Install the repository signing key:
$ curl https://packages.microsoft.com/keys/microsoft.asc |sudo apt-key add -
2.Add the ms-teams repository as a file to the apt sources.list.d:
$ echo "deb [arch=amd64] https://packages.microsoft.com/repos/ms-teams stable main" |sudo tee /etc/apt/sources.list.d/teams.list
3.Update the apt packages cache:
$ sudo apt update
4.Install teams from the newly added repository:
$ sudo apt install teams
Serge Stroobandt
  • 5,719
  • 54
  • 59
  1. Microsoft Teams Progressive Web App:
    Login at teams.microsoft.com website in a PWA-friendly web browser (anything Chromium-based), wait/hope for the “install” prompt to be shown (if not you can use the tools > ‘create a shortcut’ menu option). (Source: OMG! Linux.)
  2. Web app in the browser.
  3. Unofficial Microsoft Teams client for Linux using Electron. It uses the Web App and wraps it as a standalone application using Electron, as deb-package, AppImage, snap from the Snap Store and flatpak from the Flathub.
Discontinued
  1. Flatpak from the Flathub. [The Linux version of Microsoft Teams is no longer supported. It is recommnded to switch to PWA version, using Chrome, Chromium or Edge. See https://techcommunity.microsoft.com/t5/microsoft-teams-blog/microsoft-teams-progressive-web-app-now-available-on-linux/ba-p/3669846 for details.]
  2. December 2022 (although page https://aka.ms/get-teams-linux is still available and PWA is not shown):
    Microsoft has released an official Linux app in October 2020, if you prefer an app to the browser version of MS teams.
    I am not a fan of MS Teams but there are situations you have to use it. It seems the MS-teams app repository (see other answer) is not updated anymore.
You can install the official version as:
  1. As deb package from the official MS Teams download page. If you need more details how to install the deb package, you find it on the Website for Students. Delete configuration folders to reset Teams:
    rm -rf ~/.config/teams
    rm -rf ~/.config/Microsoft/Microsoft\ Teams
  2. As Snap package from the Software App or snapcraft.io-Page or in a terminal (sudo snap install teams).
Filbuntu
  • 13,891
Kindly follow below steps.
curl https://packages.microsoft.com/keys/microsoft.asc | sudo apt-key add -
sudo sh -c 'echo "deb [arch=amd64] https://packages.microsoft.com/repos/ms-teams stable main" > /etc/apt/sources.list.d/teams.list'
sudo apt update sudo apt install teams
Mr. Linux
  • 195
you can install by the following command
cd /tmp
wget https://packages.microsoft.com/repos/ms-teams/pool/main/t/teams/teams_1.2.00.32451_amd64.deb
dpkg -i teams_1.2.00.32451_amd64.deb
ujjal das
  • 221
