Tried to install caffeine, and it's not working.
I have Kubuntu 18.10, KDE Plazma 5.14.4
Do this way
sudo add-apt-repository ppa:caffeine-developers/ppa
sudo apt-get install caffeine
And from default Kubunto repository ubuntu-cosmic-universe with the same result.
Caffiene version on both variant was 2.9.4-1
After launch caffeine-indicator and activate from tray.
If I try to run caffeine from KDE menu, nothing happened, no window opened.
If run from console its runs without any output and without window, but don't work.
This question is a bit old, so I'll answer it for Kubuntu 20.04
  1. Remove the outdated package:
    sudo apt remove --purge caffeine && sudo apt autoremove
  2. Remove the outdated PPA:
    sudo add-apt-repository --remove ppa:caffeine-developers/ppa
  3. Install the caffeine package from the official repositories:
    sudo apt install caffeine
  4. Open a terminal and run:
    caffeine-indicator & exit
  5. Wait for about 5 seconds and you should see the indicator in your system icons widget.
If it doesn't work, try to use caffeine-indicator & instead (without exit). This will let you see the logs. If you're able to see them, please edit your question and add them there.
I tried this on my laptop and everything seems to work.
adazem009
  • 1,212
