I just want to change the username of a user with an encrypted home directory. Is there a simple way instead of the suggested restoring and so forth?
LiveWireBT
  • 29,597
  1. It's best to unmount your home directory and execute the commands from another administrator account on the computer. You could use ecryptfs-umount-private or just reboot to unmount the directory.
  2. Change the login name and directory name from old_user to new_user:
    sudo usermod -l new_user -m -d /home/new_user old_user
  3. Here comes the important part for the proper configuration:
    • There exists a file named /home/.ecryptfs/$USER/.ecryptfs/Private.mnt it usually contains the following: /home/$USER
    • The following symlinks exist in your home directory when eCryptfs is not mounted:
      .ecryptfs -> /home/.ecryptfs/$USER/.ecryptfs
      .Private ->  /home/.ecryptfs/$USER/.Private
    • Make sure that $USER in all these instances reflects the changes you intended to make, e.g. new_user. You can use nano to edit text files and ln -s to create new symlinks.
You should be able to login again. I just tried it on my own. If you cannot log in through the GUI try from the terminal and check again that everything is in place.
LiveWireBT
  • 29,597
