Note: Last question did not work on my system How do I Install CUDA on Ubuntu 18.04?
I installed the CUDA toolkit on Ubuntu 18.04, but the installation does not appear complete. How can I install CUDA properly on Ubuntu 18.04?
I followed the advice on a prior question and have nvcc installed.
When I run nvcc -V, I have CUDA compilation tools, release 9.1, V9.1.85.
Now I am searching for the bin directory to test the installation. See Section 7.0: https://docs.nvidia.com/cuda/cuda-installation-guide-linux/index.html#post-installation-actions
The only two cuda folders I find with locate are under the anaconda3 directory. Neither of these have a bin folder.
I suggest you to use "find" command instead of "locate".
I assume you installed via apt and because it has become a native package, CUDA is installed in a rather non-standard way.
They are installed into the root system paths: /usr/bin, /usr/include, /usr/lib we need to emulate the old way for it to work. The following commands should do the trick:
sudo mkdir -p /usr/local/cuda /usr/local/cuda/extras/CUPTI /usr/local/cuda/nvvm
sudo ln -s /usr/bin /usr/local/cuda/bin
sudo ln -s /usr/include /usr/local/cuda/include
sudo ln -s /usr/lib/x86_64-linux-gnu /usr/local/cuda/lib64
sudo ln -s /usr/local/cuda/lib64 /usr/local/cuda/lib
sudo ln -s /usr/include /usr/local/cuda/extras/CUPTI/include
sudo ln -s /usr/lib/x86_64-linux-gnu /usr/local/cuda/extras/CUPTI/lib64
sudo ln -s /usr/lib/nvidia-cuda-toolkit/libdevice /usr/local/cuda/nvvm/libdevice
Resource: https://medium.com/@asmello/how-to-install-tensorflow-cuda-9-1-into-ubuntu-18-04-b645e769f01d
