I met this error while updating.I read questions and answers about this problem , but the point is signing key. It doesn't return signing key!
Get:1 http://archive.canonical.com lucid Release.gpg [198B]
Ign http://archive.canonical.com/ lucid/partner Translation-en_US
Get:24 http://archive.ubuntu.com lucid-security/main Packages [380kB]
Get:25 http://archive.ubuntu.com lucid-security/restricted Packages [14B]
Get:26 http://archive.ubuntu.com lucid-security/multiverse Packages [4,556B]
Get:27 http://archive.ubuntu.com lucid-security/main Sources [118kB]
Get:28 http://archive.ubuntu.com lucid-security/restricted Sources [14B]
Get:29 http://archive.ubuntu.com lucid-security/universe Packages [125kB]
Get:30 http://archive.ubuntu.com lucid-security/universe Sources [34.5kB]
Fetched 12.8MB in 10min 33s (20.3kB/s)
Reading package lists... Done
W: GPG error: http://archive.canonical.com lucid Release: Unknown error executing gpgv
W: GPG error: http://archive.ubuntu.com lucid Release: Unknown error executing gpgv
W: GPG error: http://archive.ubuntu.com lucid-updates Release: Unknown error executing gpgv
W: GPG error: http://archive.ubuntu.com lucid-security Release: Unknown error executing gpgv
Mochan
  • 1,708
mohammads
  • 2,654
Finally , fixed .
I searched in /lib and found an other "libreadline.so.6" and replaced it and problem fixed.
Thank you for your attention.
mohammads
  • 2,654
Try sudo apt-get clean and then run the update command again.
LnxSlck
  • 12,456
well... same problem here (ubuntu 12.04 , 64bit). This worked for me:
sudo mv /usr/local/lib/libreadline.so.6 /usr/local/lib/libreadline_problem.so.6
sudo mv /usr/local/lib/libreadline.so.6.2 /usr/local/lib/libreadline_problem.so.6.2
sudo ln -s /lib/x86_64-linux-gnu/libreadline.so.6 /usr/local/lib/libreadline.so.6
sudo ln -s /lib/x86_64-linux-gnu/libreadline.so.6.2 /usr/local/lib/libreadline.so.6.2
sudo  apt-get update
guntbert
  • 13,475
hubble
Please run the following command and add the key manually:
gpg --keyserver hkp://keyserver.ubuntu.com:80 --recv KEYNAME
IT UPT
