Possible Duplicate:
Environment variables when run with 'sudo'
I've added a new folder to my path, but when running the programs (in that folder) with "sudo" it does not work.
When I type
sudo <command-name>
it returns:
sudo: <command-name>: command not found
How do I make it available for sudo?
MhdSyrwan
  • 311
That's strange. Anyway I think that
sudo /FULL_PATH/program_name
will work.
Another good idea will be to add a symbolic link to it in the /sbin/ directory with
sudo ln -s /FULL_PATH/program_name /sbin
dadexix86
  • 6,776
The PATH is located in your ~/.profile, ~/.bashrc, or ~/.bash_profile file. This file is made for your account only.
When you set your PATH, you probably editted /home/yourname/.profile right? Sudo doesnt (as one might think) uses the PATH from /root/.profile instead of /home/yourname/, nor does it always use your own PATH.
The problem is that a couple of variables are overwritten by sudo. Which ones depends on your system. As root, run:
sudo -V
It will tell you if your PATH is used or not. You could then use sudo -E option to overwrite the using of the default PATH. See the description in the manpage about the /etc/sudoers file.
xatr0z
  • 125
