How do you make the scripts in /home/$user/bin accessible using sudo? as in:
sudo $NameOfScript
in using Ubuntu 12.04
John
  • 691
Environment variables are reset for sudo for security reasons, including the PATH variable that controls which programs you can run conveniently at a prompt.
However, you can bypass this limitation by specifying the absolute or relative path to the command you want to use. In your example:
sudo /home/$user/bin/$NameOfScript
As compared to the approach of changing PATH, this preserves the security precautions around root's environment variables while still allowing you to run whatever program you want with sudo.
Paul
  • 7,194
