I find apt in terminal as the best way to install a program from a deb package. As I prefer it to other gui tools, I want that in the context menu for deb files or as a launcher among applications in order to install the deb by executing it with (double) click.
In Kubuntu with Dolphin I have created a service menu to create that context menu, also a desktop file in ~/.local/share/applications to achieve the same action by executing the deb file.
The file ~/.local/share/kservices5/ServiceMenus/install-deb.desktop:
[Desktop Entry]
Actions=install
Icon=dialog-information
MimeType=application/vnd.debian.binary-package
ServiceTypes=KonqPopupMenu/Plugin
Type=Service
X-KDE-Priority=TopLevel
[Desktop Action install]
Exec=konsole --hold -e sudo apt install %f
Name=Install
The file ~/.local/share/applications/install_deb_term.desktop:
[Desktop Entry]
Name=Install in terminal with apt
Comment=Install deb files in terminal with apt
Icon=gdebi
Terminal=false
Type=Application
StartupNotify=true
Categories=GNOME;GTK;Settings;HardwareSettings;X-GNOME-Settings-Panel;System;
All is well, excepting the fact that without the --hold argument in konsole the terminal closes to quickly (which is not good in case of error), while with that argument the terminal stays open with a rather inconclusive message like so:
Setting up <whatever_program> ...
which is not what I expect if the installation went fine.
Can I get some "OK" message at the end of the installation process with apt? Maybe through a script containing the apt command?
Update:
Following comments by @DKBose: modifying ~/.bashrc as in this answer I get the desired notification popup with a command in terminal like
sudo apt install /path/to/deb; alert
but not with the line
Exec=konsole --hold -e sudo apt install %f; alert
in the files above (installation works, but no popup).
For the alert argument to work at all, installation of libnotify-bin was needed.
