On one of my computers, clicking on an Icon on the launcher that has multiple application grouped will toggle between opening all the Windows in the group, or minimzing all the windows in the group.
On all the other computers, when there is more than one item on the icon, it will bring up the list and allow the user scroll through the icon list and click on just one application.
Does anyone know how to change this behavior to the default, whereas it will bring up the list if there is more than one icon in the group, and toggle restore/minimize when there is only one in the group?
You can see this list with a sequence of keystrokes:
  • right click the icon
  • click all windows
  • click the application instance from the list
pomsky
  • 70,557
L. D. James
  • 25,444
You can use gsettings to achieve your goal
If you run
gsettings get org.gnome.shell.extensions.dash-to-dock click-action
you should see different outputs for two different cases you mentioned, for example in the first scenario it should give minimize whereas in the second case it should be previews.
To set the preferred option as per the output of the command above, run
gsettings set org.gnome.shell.extensions.dash-to-dock click-action 'YOUR-PREFERRED-OPTION'
In particular, to achieve your goal, run
gsettings set org.gnome.shell.extensions.dash-to-dock click-action 'previews'
pomsky
  • 70,557
You can user dconf editor GUI tool to update these changes easily
sudo apt-get update
sudo apt-get install dconf-editor
dconf-editor
