The building of tarball releases of GNU m4 1.4.10 to 1.4.18 (didn't test all hotfix versions, but I assume the error is consistent among this range) with ./configure && make -j1 and git git repository http://git.savannah.gnu.org/r/m4.git with ./bootstrap && ./configure && make -j1 (commit cvs-readonly-359-gd69fa528 i.e. HEAD of master) fails due to
freadahead.c: In function 'freadahead':
freadahead.c:92:3: error: #error "Please port gnulib freadahead.c to your platform! Look at the definition of fflush, fread, ungetc on your system, then report this to bug-gnulib."
make[3]: *** [Makefile:1910: freadahead.o] Error 1
make[3]: Leaving directory '/mnt/data/sources/m4-1.4.18/lib'
I'm very confused by this error and according to a superficial google search the problem is the consequence of an overly long ignored upstream update, see e.g. https://bugzilla.redhat.com/show_bug.cgi?id=1573342 with the genius documentation of the fix "Thanks for the bug report, fixed!" - if that doesn't help others...
I tried to build glibc from source and install it into a custom prefix[1]. 2.28 and 2.27 exhibit the same issue and 2.26 fails due to
make[2]: Verzeichnis „/mnt/data/sources/glibc-2.26/inet“ wird betreten
gcc ../sysdeps/unix/sysv/linux/if_index.c -c -std=gnu11 -fgnu89-inline  -O2 -Wall -Werror -Wundef -Wwrite-strings -fmerge-all-constants -fno-stack-protector -frounding-math -g -Wstrict-prototypes -Wold-style-definition     -ftls-model=initial-exec   -U_FORTIFY_SOURCE   -I../include -I/mnt/data/sources/glibc-2.26-build/inet  -I/mnt/data/sources/glibc-2.26-build  -I../sysdeps/unix/sysv/linux/x86_64/64  -I../sysdeps/unix/sysv/linux/x86_64  -I../sysdeps/unix/sysv/linux/x86  -I../sysdeps/x86/nptl  -I../sysdeps/unix/sysv/linux/wordsize-64  -I../sysdeps/x86_64/nptl  -I../sysdeps/unix/sysv/linux/include -I../sysdeps/unix/sysv/linux  -I../sysdeps/nptl  -I../sysdeps/pthread  -I../sysdeps/gnu  -I../sysdeps/unix/inet  -I../sysdeps/unix/sysv  -I../sysdeps/unix/x86_64  -I../sysdeps/unix  -I../sysdeps/posix  -I../sysdeps/x86_64/64  -I../sysdeps/x86_64/fpu/multiarch  -I../sysdeps/x86_64/fpu  -I../sysdeps/x86/fpu/include -I../sysdeps/x86/fpu  -I../sysdeps/x86_64/multiarch  -I../sysdeps/x86_64  -I../sysdeps/x86  -I../sysdeps/ieee754/float128  -I../sysdeps/ieee754/ldbl-96/include -I../sysdeps/ieee754/ldbl-96  -I../sysdeps/ieee754/dbl-64/wordsize-64  -I../sysdeps/ieee754/dbl-64  -I../sysdeps/ieee754/flt-32  -I../sysdeps/wordsize-64  -I../sysdeps/ieee754  -I../sysdeps/generic  -I.. -I../libio -I.   -D_LIBC_REENTRANT -include /mnt/data/sources/glibc-2.26-build/libc-modules.h -DMODULE_NAME=libc -include ../include/libc-symbols.h  -DPIC     -DTOP_NAMESPACE=glibc -o /mnt/data/sources/glibc-2.26-build/inet/if_index.o -MD -MP -MF /mnt/data/sources/glibc-2.26-build/inet/if_index.o.dt -MT /mnt/data/sources/glibc-2.26-build/inet/if_index.o
../sysdeps/unix/sysv/linux/if_index.c: In function ‘__if_nametoindex’:
../sysdeps/unix/sysv/linux/if_index.c:46:3: error: ‘strncpy’ specified bound 16 equals destination size [-Werror=stringop-truncation]
   strncpy (ifr.ifr_name, ifname, sizeof (ifr.ifr_name));
cc1: all warnings being treated as errors
make[2]: *** [/mnt/data/sources/glibc-2.26-build/sysd-rules:213: /mnt/data/sources/glibc-2.26-build/inet/if_index.o] Fehler 1
make[2]: Verzeichnis „/mnt/data/sources/glibc-2.26/inet“ wird verlassen
make[1]: *** [Makefile:215: inet/subdir_lib] Fehler 2
make[1]: Verzeichnis „/mnt/data/sources/glibc-2.26“ wird verlassen
make: *** [Makefile:9: all] Fehler 2
and 2.25 due to
strftime_l.c: In function ‘__strftime_internal’:
strftime_l.c:719:4: error: macro expands to multiple statements [-Werror=multistatement-macros]
    digits = d > width ? d : width;          \
strftime_l.c:1260:6: note: in expansion of macro ‘DO_NUMBER’
      DO_NUMBER (1, tp->tm_year + TM_YEAR_BASE);
strftime_l.c:1259:4: note: some parts of macro expansion are not guarded by this ‘else’ clause
    else
In file included from wcsftime_l.c:23:
    else
make[2]: *** [../o-iterator.mk:9: /mnt/data/sources/glibc-2.25-build/time/strftime_l.os] Fehler 1
which made me decide to not try out further version.
[The discussion on a report about a similar issue in findutils] suggests to overwrite freadahead.{c,h} from an up-to-date gnulib source root. This causes a chain of problems which is unnecessary to document here as I don't know what I'm doing.
How to get started with fixing, reporting and/or working around this issue?
I'm building m4 from source for a bootstrap script for systems where a user doesn't have privileges to use the package manager. I'm really just interested in building the original GNU m4 from release source tarballs.
An overview of build results on other similarily bare systems is provided at https://gitlab.com/krichter/m4/pipelines/36977411.
[1] In case you're investigating this always install glibc into a custom prefix because an installation in the default prefix /usr/local will most certainly ruine your system. Consider using checkinstall to be sure.
Try applying this patch. It is an OpenEmbedded-generated backport of upstream patch.
Thymo
  • 103
lumag
  • 121
If you want to build m4 from source then start by getting its build dependencies from the repository:
  1. enable Source code in the Software & Updates (software-properties-gtk)
  2. install needed build tools
    sudo apt-get install build-essential
  3. get necessary build dependencies for current m4 binary package
    sudo apt-get build-dep m4
  4. get source code of the current m4 binary package (with all needed patches provided by Debian and/or Ubuntu):
    apt-get source m4
    cd m4-*
  5. then compile it as usual
N0rbert
  • 103,263
