I've just completed a fresh install of Ubuntu Server 18.04 on dedicated hardware. After login, the bonded network interface is not assigned an IP from DHCP. If I run sudo dhclient the bonded interface gets an IP and everything appears to work. After a reboot, I'm back to a non-working network.
If I execute sudo ip address show I can see that my interface is down. After sudo ip link bond0 up the interface comes up without an IP.
I've looked at this question already: Ubuntu 18.04 ethernet not configuring automatically That question does not address my problem. The question includes ifup which is not available on my system. The accepted answer includes /etc/network/interfaces which is not available on 18.04.
I've looked at this question: Ubuntu Server 18.04 waiting for Network at startup although the network is ok which specifically calls out wireless, which is not my situation and also does not have an accepted answer.
There's this question: Ubuntu server 18.04 - No IP address with Netplan This is a zero reputation question with no answer. There's one comment that recommends capturing packets and submitting a bug report. I've run a packet capture with tcpdump on DHCP traffic and the only data I get is 10 packets dropped by interface (I assume this was not DCHP traffic).
I did not find any other existing questions that seemed related.
So my question is twofold:
- Is this a bug?
- Am I expected to manually set up a networking interface after installation?
Edit: Additional Information
lshw:
*-network:0
description: Ethernet interface
product: 82576 Gigabit Network Connection
vendor: Intel Corporation
physical id: 0
bus info: pci@0000:05:00.0
logical name: enp5s0f0
version: 01
serial: 3e:e4:cf:e3:41:b2
capacity: 1Gbit/s
width: 32 bits
clock: 33MHz
capabilities: pm msi msix pciexpress bus_master cap_list rom ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=igb driverversion=5.4.0-k duplex=full firmware=1.2.3 latency=0 link=yes multicast=yes port=twisted pair slave=yes speed=1Gbit/s
resources: irq:25 memory:c0000000-c001ffff memory:c0020000-c003ffff ioport:ef80(size=32) memory:c00c0000-c00c3fff memory:c0040000-c005ffff memory:c00c4000-c00e3fff memory:c00e4000-c0103fff
*-network:1
physical id: 0.1
bus info: pci@0000:05:00.1
logical name: enp5s0f1
version: 01
capacity: 1Gbit/s
width: 32 bits
clock: 33MHz
resources: irq:35 memory:c0060000-c007ffff memory:c0080000-c009ffff ioport:ef40(size=32) memory:c0104000-c0107fff memory:c00a0000-c00bffff memory:c0108000-c0127fff memory:c0128000-c0147fff
*-network DISABLED
physical id: 1
logical name: bond0
capabilities: ethernet physical
configuration: autonegotiation=off broadcast=yes driver=bonding driverversion=3.7.1 duplex=full firmware=2 link=no master=yes multicast=yes speed=1Gbit/s
/etc/netplan/*.yaml:
# This file is generated from information provided by
# the datasource. Changes to it will not persist across an instance.
# To disable cloud-init's network configuration capabilities, write a file
# /etc/cloud/cloud.cfg.d/99-disable-network-config.cfg with the following:
# network: {config: disabled}
network:
bonds:
bond0:
addresses: []
interfaces:
- enp5s0f0
- enp5s0f1
parameters:
mode: active-backup
ethernets:
enp5s0f0:
addresses: []
dhcp4: false
dhcp6: false
enp5s0f1:
addresses: []
dhcp4: false
dhcp6: false
version: 2
