I have a laptop with Ubuntu 18.04 Desktop installed. The system is eager to configure and operate WiFi, but I need a wired connection because my adapter is slow compared to the 1000BASE-T Ethernet.
Ethernet cable is plugged in, but I see nowhere in the desktop how to configure wired. With WiFi off, there's a "?" next to the volume control. Clicking there shows nothing to do with an Ethernet connection.
On the other hand, if I manually bring the interface up, networking works just fine:
% sudo ifup enp5s0f1
Internet Systems Consortium DHCP Client 4.3.5
Copyright 2004-2016 Internet Systems Consortium.
All rights reserved.
For info, please visit https://www.isc.org/software/dhcp/
Listening on LPF/enp5s0f1/78:24:af:ca:08:74
Sending on LPF/enp5s0f1/78:24:af:ca:08:74
Sending on Socket/fallback
DHCPDISCOVER on enp5s0f1 to 255.255.255.255 port 67 interval 3 (xid=0x637da107)
DHCPDISCOVER on enp5s0f1 to 255.255.255.255 port 67 interval 5 (xid=0x637da107)
DHCPREQUEST of 192.168.1.24 on enp5s0f1 to 255.255.255.255 port 67 (xid=0x7a17d63)
DHCPOFFER of 192.168.1.24 from 192.168.1.1
DHCPACK of 192.168.1.24 from 192.168.1.1
bound to 192.168.1.24 -- renewal in 41444 seconds.
ssh, ftp, web browser... just works.
I've added information that was requested below:
% sudo lshw -C network
*-network DISABLED
description: Wireless interface
product: AR9462 Wireless Network Adapter
vendor: Qualcomm Atheros
physical id: 0
bus info: pci@0000:04:00.0
logical name: wlp4s0
version: 01
serial: 40:e2:30:ae:5b:17
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list rom ethernet physical wireless
configuration: broadcast=yes driver=ath9k driverversion=4.15.0-36-generic firmware=N/A latency=0 link=no multicast=yes wirele
ss=IEEE 802.11
resources: irq:18 memory:f7900000-f797ffff memory:f7980000-f798ffff
*-network DISABLED
description: Ethernet interface
product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0.1
bus info: pci@0000:05:00.1
logical name: enp5s0f1
version: 12
serial: 78:24:af:ca:08:74
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000
bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full latency=0 link=no multicast
=yes port=MII speed=1Gbit/s
resources: irq:19 ioport:d000(size=256) memory:f7814000-f7814fff memory:f7810000-f7813fff
Grepping for NetworkManager in syslog:
/var/log/syslog.1:Oct 17 21:24:28 myhostname NetworkManager[802]: [1539825868.9200] bluez5: NAP: removed interface 40:E2:30:AE:5B:16 /var/log/syslog.1:Oct 17 21:24:29 myhostname NetworkManager[802]: [1539825869.1167] manager: sleep: wake requested (sleeping: yes enabled: yes) /var/log/syslog.1:Oct 17 21:24:29 myhostname NetworkManager[802]: [1539825869.1169] device (wlp4s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'managed') /var/log/syslog.1:Oct 17 21:24:29 myhostname NetworkManager[802]: [1539825869.1174] manager: NetworkManager state is now DISCONNECTED /var/log/syslog.1:Oct 17 21:24:29 myhostname NetworkManager[802]: [1539825869.7907] bluez5: NAP: added interface 40:E2:30:AE:5B:16 /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.7085] NetworkManager (version 1.10.6) is starting... (for the first time) /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.7086] Read config: /etc/NetworkManager/NetworkManager.conf (lib: 10-dns-resolved.conf, 20-connectivity-ubuntu.conf, no-mac-addr-change.conf) (run: 10-globally-managed-devices.conf) (etc: default-wifi-powersave-on.conf) /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.7123] manager[0x55ae928e6060]: monitoring kernel firmware directory '/lib/firmware'. /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.7124] monitoring ifupdown state file '/run/network/ifstate'. /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8188] hostname: hostname: using hostnamed /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8189] hostname: hostname changed from (none) to "myhostname" /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8192] dns-mgr[0x55ae92900140]: init: dns=systemd-resolved, rc-manager=symlink, plugin=systemd-resolved /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8199] rfkill1: found WiFi radio killswitch (at /sys/devices/pci0000:00/0000:00:1c.2/0000:04:00.0/ieee80211/phy0/rfkill1) (driver ath9k) /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8200] manager[0x55ae928e6060]: rfkill: WiFi hardware radio set disabled /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8201] manager[0x55ae928e6060]: rfkill: WWAN hardware radio set enabled /var/log/syslog.1:Oct 17 21:29:46 myhostname dbus-daemon[775]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.14' (uid=0 pid=800 comm="/usr/sbin/NetworkManager --no-daemon " label="unconfined") /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8363] init! /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8364] interface-parser: parsing file /etc/network/interfaces /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8364] interface-parser: finished parsing file /etc/network/interfaces /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8366] guessed connection type (enp5s0f1) = 802-3-ethernet /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8366] update_connection_setting_from_if_block: name:enp5s0f1, type:802-3-ethernet, id:Ifupdown (enp5s0f1), uuid: a4537f7b-6324-fd3f-6489-f76bfb2af0dc /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8367] adding enp5s0f1 to connections /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8367] adding iface enp5s0f1 to eni_ifaces /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8367] management mode: unmanaged /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8371] devices added (path: /sys/devices/pci0000:00/0000:00:1c.2/0000:04:00.0/net/wlp4s0, iface: wlp4s0) /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8371] device added (path: /sys/devices/pci0000:00/0000:00:1c.2/0000:04:00.0/net/wlp4s0, iface: wlp4s0): no ifupdown configuration found. /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8371] devices added (path: /sys/devices/pci0000:00/0000:00:1c.3/0000:05:00.1/net/enp5s0f1, iface: enp5s0f1) /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8372] locking wired connection setting /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8372] settings-connection[0x55ae928b2360,a4537f7b-6324-fd3f-6489-f76bfb2af0dc]: write: failure to update connection: writing settings not supported /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8372] devices added (path: /sys/devices/virtual/net/lo, iface: lo) /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8372] device added (path: /sys/devices/virtual/net/lo, iface: lo): no ifupdown configuration found. /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8372] end _init. /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8372] settings: loaded plugin ifupdown: (C) 2008 Canonical Ltd. To report bugs please use the NetworkManager mailing list. (/usr/lib/x86_64-linux-gnu/NetworkManager/libnm-settings-plugin-ifupdown.so) /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8373] settings: loaded plugin keyfile: (c) 2007 - 2016 Red Hat, Inc. To report bugs please use the NetworkManager mailing list. /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8373] (-1835934528) ... get_connections. /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8373] (-1835934528) ... get_connections (managed=false): return empty list. /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8464] keyfile: new connection /etc/NetworkManager/system-connections/Wired connection 1 (823e4837-330a-3bf9-8be5-6fc1f1fde418,"Wired connection 1") /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8543] keyfile: new connection /etc/NetworkManager/system-connections/Necronomicon (b247a602-6c61-4875-af1e-58d0d88bbd81,"Necronomicon") /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8548] get unmanaged devices count: 1 /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8548] manager: rfkill: WiFi disabled by radio killswitch; disabled by state file /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8548] manager: rfkill: WWAN enabled by radio killswitch; enabled by state file /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8548] manager: Networking is enabled by state file /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8549] dhcp-init: Using DHCP client 'dhclient' /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8550] Loaded device plugin: NMBondDeviceFactory (internal) /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8550] Loaded device plugin: NMBridgeDeviceFactory (internal) /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8550] Loaded device plugin: NMDummyDeviceFactory (internal) /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8550] Loaded device plugin: NMEthernetDeviceFactory (internal) /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8550] Loaded device plugin: NMInfinibandDeviceFactory (internal) /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8550] Loaded device plugin: NMIPTunnelDeviceFactory (internal) /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8550] Loaded device plugin: NMMacsecDeviceFactory (internal) /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8550] Loaded device plugin: NMMacvlanDeviceFactory (internal) /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8551] Loaded device plugin: NMPppDeviceFactory (internal) /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8551] Loaded device plugin: NMTunDeviceFactory (internal) /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8551] Loaded device plugin: NMVethDeviceFactory (internal) /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8551] Loaded device plugin: NMVlanDeviceFactory (internal) /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8551] Loaded device plugin: NMVxlanDeviceFactory (internal) /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8570] Loaded device plugin: NMWwanFactory (/usr/lib/x86_64-linux-gnu/NetworkManager/libnm-device-plugin-wwan.so) /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8580] Loaded device plugin: NMAtmManager (/usr/lib/x86_64-linux-gnu/NetworkManager/libnm-device-plugin-adsl.so) /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8602] Loaded device plugin: NMBluezManager (/usr/lib/x86_64-linux-gnu/NetworkManager/libnm-device-plugin-bluetooth.so) /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8611] Loaded device plugin: NMWifiFactory (/usr/lib/x86_64-linux-gnu/NetworkManager/libnm-device-plugin-wifi.so) /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8635] Loaded device plugin: NMTeamFactory (/usr/lib/x86_64-linux-gnu/NetworkManager/libnm-device-plugin-team.so) /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8641] device (lo): carrier: link connected /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8646] manager: (lo): new Generic device (/org/freedesktop/NetworkManager/Devices/1) /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8655] manager: (enp5s0f1): new Ethernet device (/org/freedesktop/NetworkManager/Devices/2) /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8663] wifi-nl80211: (wlp4s0): using nl80211 for WiFi device control /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8664] device (wlp4s0): driver supports Access Point (AP) mode /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8670] manager: (wlp4s0): new 802.11 WiFi device (/org/freedesktop/NetworkManager/Devices/3) /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8679] device (wlp4s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external') /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8723] bluez: use BlueZ version 5 /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8735] modem-manager: ModemManager available /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8757] supplicant: wpa_supplicant running /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8760] manager: startup complete /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8767] bluez5: NAP: added interface 40:E2:30:AE:5B:16
Grepping for enp5s0f1:
/var/log/syslog.1:Oct 17 21:29:46 myhostname kernel: [ 1.210408] r8169 0000:05:00.1 enp5s0f1: renamed from eth0 /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8366] guessed connection type (enp5s0f1) = 802-3-ethernet /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8366] update_connection_setting_from_if_block: name:enp5s0f1, type:802-3-ethernet, id:Ifupdown (enp5s0f1), uuid: a4537f7b-6324-fd3f-6489-f76bfb2af0dc /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8367] adding enp5s0f1 to connections /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8367] adding iface enp5s0f1 to eni_ifaces /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8371] devices added (path: /sys/devices/pci0000:00/0000:00:1c.3/0000:05:00.1/net/enp5s0f1, iface: enp5s0f1) /var/log/syslog.1:Oct 17 21:29:46 myhostname NetworkManager[800]: [1539826186.8655] manager: (enp5s0f1): new Ethernet device (/org/freedesktop/NetworkManager/Devices/2)
Contents of /etc/network/interfaces:
# interfaces(5) file used by ifup(8) and ifdown(8) auto lo iface lo inet loopback iface enp5s0f1 inet dhcp
From /etc/netplan/01-network-manager-all.yaml
# Let NetworkManager manage all devices on this system network: version: 2 renderer: NetworkManager
Thanks for any help,
Charles
