I am currently using Lubuntu 18.04
I thought that theese are the 3 right code lines to drop cache:
sync; echo 1 > /proc/sys/vm/drop_caches
sync; echo 2 > /proc/sys/vm/drop_caches
sync; echo 3 > /proc/sys/vm/drop_caches
I've tried three all with and without sudo and the output is permission denied.
 sudo sync; echo 1 > /proc/sys/vm/drop_caches
bash: /proc/sys/vm/drop_caches: Permission denied
I have all windows closed, no applications running but still permission denied...
I am clearly doing something wrong, Could anyone tell me which is the right way to drop caches in Lubuntu?
Thanks in advance
ft18
  • 451
Finally I found something that works...
sync
sudo sh -c "echo 1 > /proc/sys/vm/drop_caches"
sync
sudo sh -c "echo 2 > /proc/sys/vm/drop_caches"
sync
sudo sh -c "echo 3 > /proc/sys/vm/drop_caches"
And if you want to drop thumbnails make this:
rm -v -f ~/.cache/thumbnails/*/*.png ~/.thumbnails/*/*.png
 rm -v -f ~/.cache/thumbnails/*/*/*.png ~/.thumbnails/*/*/*.png
Of course you should use:
sudo apt clean
sudo apt autoclean
And that would be all... At least I thought so... but I may be wrong...
ft18
  • 451
The easiest way is with a script lifted here:
#!/bin/bash
if [[ $(id -u) -ne 0 ]] ; then echo "Please run as root" ; exit 1 ; fi
Call the script drop-caches.
Mark it as executable using chmod a+x drop-caches
Call it using sudo ./drop-caches
If you place the script in /usr/local/bin you can call it using sudo drop-caches
