I have been trying to enable my bluetooth of my laptop (Lenovo Ideapad-Y400), it comes with a Atheros bluetooth that has some problems with the kernel.
First of all I wasn't able to turn on my bluetooth, but I realized that runing sudo rfkill block bluetooth twice, and then run againt twice sudo rfkill unblock bluetooth, the bluetooth configuration menu was able to find devices and pair them but it crash after 1 minute, then the bluetooth is not able to find anything. Also, if I turn off the bluetooth in that particular case, I'm not able to turn it on again, I have to run again rfkill un/block to toggle it on.
Then, I tried the solution from here, and it worked like a charm, now I can turn on and off my bluetooth. Seems the version of my kernel had that problem, also I installed Ukuu, to install a newer kernel, but my graphics card crashes (right now I'm using the patched kernel to make my bluetooth work "Linux 4.15.0.39.48"). But now my bluetooth can't find any device. I tried running bluetoothctl, and I powered on it (power on), and make it discoverable (discoverable on), and also running scan on my computer is not able to find any device, same running hcitool. Same thing installing bluez.
Can you help me with this guys?
Thank you so much.
Here I'm adding some outputs that in some forums ask them to get the context of the system.
lsusb output:
tonny@tonny-IdeaPad:~$ lsusb
Bus 002 Device 005: ID 413c:2005 Dell Computer Corp. RT7D50 Keyboard
Bus 002 Device 004: ID 1c4f:0054 SiGma Micro
Bus 002 Device 003: ID 05e3:0608 Genesys Logic, Inc. Hub
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 003: ID 0cf3:3004 Atheros Communications, Inc. AR3012 Bluetooth 4.0
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 003: ID 2341:0010 Arduino SA Mega 2560 (CDC ACM)
Bus 003 Device 002: ID 5986:0295 Acer, Inc
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
lspci -nnk | grep -iA3 net; lsusb; rfkill list; uname -r; dmesg | egrep -i 'blue|firm' output:
02:00.0 Ethernet controller [0200]: Qualcomm Atheros AR8161 Gigabit Ethernet [1969:1091] (rev 10)
Subsystem: Realtek Semiconductor Co., Ltd. AR8161 Gigabit Ethernet [10ec:0123]
Kernel driver in use: alx
Kernel modules: alx
03:00.0 Network controller [0280]: Qualcomm Atheros AR9485 Wireless Network Adapter [168c:0032] (rev 01)
Subsystem: Lenovo AR9485 Wireless Network Adapter [17aa:3218]
Kernel driver in use: ath9k
Kernel modules: ath9k
04:00.0 System peripheral [0880]: JMicron Technology Corp. SD/MMC Host Controller [197b:2392] (rev 30)
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
1: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
2: ideapad_wlan: Wireless LAN
Soft blocked: no
Hard blocked: no
3: ideapad_bluetooth: Bluetooth
Soft blocked: no
Hard blocked: no
4.15.0-39-generic
[ 0.029218] Spectre V2 : Enabling Restricted Speculation for firmware calls
[ 0.062621] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[ 2.567931] [Firmware Bug]: Duplicate ACPI video bus devices for the same VGA controller, please try module parameter "video.allow_duplicates=1"if the current driver doesn't work.
[ 2.567935] [Firmware Bug]: Duplicate ACPI video bus devices for the same VGA controller, please try module parameter "video.allow_duplicates=1"if the current driver doesn't work.
[ 2.567939] [Firmware Bug]: Duplicate ACPI video bus devices for the same VGA controller, please try module parameter "video.allow_duplicates=1"if the current driver doesn't work.
[ 2.567943] [Firmware Bug]: Duplicate ACPI video bus devices for the same VGA controller, please try module parameter "video.allow_duplicates=1"if the current driver doesn't work.
[ 2.567947] [Firmware Bug]: Duplicate ACPI video bus devices for the same VGA controller, please try module parameter "video.allow_duplicates=1"if the current driver doesn't work.
[ 3.278355] usb 1-1.3: Product: Bluetooth USB Host Controller
[ 28.220952] Bluetooth: Core ver 2.22
[ 28.220966] Bluetooth: HCI device and connection manager initialized
[ 28.220969] Bluetooth: HCI socket layer initialized
[ 28.220971] Bluetooth: L2CAP socket layer initialized
[ 28.220976] Bluetooth: SCO socket layer initialized
[ 384.853147] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 384.853148] Bluetooth: BNEP filters: protocol multicast
[ 384.853151] Bluetooth: BNEP socket layer initialized
[ 384.859967] Bluetooth: RFCOMM TTY layer initialized
[ 384.859973] Bluetooth: RFCOMM socket layer initialized
[ 384.859978] Bluetooth: RFCOMM ver 1.11
[ 390.827177] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 406.953061] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 415.912118] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 432.037908] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 447.907815] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 464.034678] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 479.904574] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 496.030502] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 511.900372] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 528.026264] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 543.896136] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 560.022140] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 575.891942] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 592.020923] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 607.894811] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 624.023613] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 777.881657] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 794.008537] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 809.879435] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 826.007324] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 841.878218] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 858.005108] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 873.876001] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 890.002848] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 905.872706] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 921.999639] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 937.870565] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 953.997372] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 969.868344] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 985.994169] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 1001.865092] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 1017.992021] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 1033.861796] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 1049.988802] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 1065.859696] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 1081.985522] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 1097.856388] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 1113.984241] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 1129.857239] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 1145.985096] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 1161.856925] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 1177.984835] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 1193.856821] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 1209.984714] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 1225.856513] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 1241.983407] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 1257.855314] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 1273.982145] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 1289.854167] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 1305.982240] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 1321.852850] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 1337.979835] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 1353.851642] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 1369.978715] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 1385.849399] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 1401.977363] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 1417.848295] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 1433.975231] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 1449.846078] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 1465.972883] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 1481.843773] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 1497.970744] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 1513.842642] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 1529.969438] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 1545.840336] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 1561.967232] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 1577.838132] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 1593.965101] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 1609.835897] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 1625.962878] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 1641.833680] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 1657.959569] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 1673.830460] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 1689.957340] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 1705.828338] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 1721.955222] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 1737.826076] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 1753.952992] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 1769.823808] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 1785.949672] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 1801.820675] Bluetooth: hci0: last event is not cmd complete (0x0f)
[ 1817.947455] Bluetooth: hci0: last event is not cmd complete (0x0f)
Edit 1:
systemd-analyze blame | nc termbin.com 9999 output:
http://termbin.com/yxiq
This has inside:
4min 29.496s apt-daily-upgrade.service
2min 24.962s apt-daily.service
29.199s systemd-journal-flush.service
23.755s dev-sda3.device
14.333s systemd-udevd.service
12.446s systemd-sysctl.service
10.066s snap-core-5662.mount
6.799s snapd.service
6.294s NetworkManager-wait-online.service
5.449s NetworkManager.service
4.790s dev-loop9.device
4.690s networkd-dispatcher.service
4.686s dev-loop16.device
4.563s dev-loop18.device
4.483s keyboard-setup.service
4.438s plymouth-quit-wait.service
4.026s dev-loop8.device
3.987s dev-loop17.device
3.953s dev-loop23.device
3.671s dev-loop13.device
3.587s dev-loop21.device
3.521s dev-loop10.device
3.483s dev-loop24.device
3.480s winbind.service
3.239s dev-loop0.device
3.078s home.mount
2.961s udisks2.service
2.915s plymouth-start.service
2.832s systemd-modules-load.service
2.563s dev-loop22.device
2.560s dev-loop20.device
2.558s dev-loop19.device
2.557s dev-loop14.device
2.556s dev-loop15.device
2.418s dev-loop12.device
2.416s dev-loop11.device
2.414s dev-loop7.device
2.388s grub-common.service
2.367s apparmor.service
2.256s systemd-fsck@dev-disk-by\x2duuid-1d27b8c5\x2db30c\x2d48e3\x2d85ff\x2d4d20591d080f.service
1.952s dev-loop3.device
1.852s dev-loop5.device
1.816s systemd-rfkill.service
1.617s snap-core-5742.mount
1.586s gdm.service
1.582s ModemManager.service
1.573s snap-gtk\x2dcommon\x2dthemes-818.mount
1.527s snap-gtk\x2dcommon\x2dthemes-701.mount
1.521s dev-loop2.device
1.517s swapfile.swap
1.468s dev-loop4.device
1.450s snap-gnome\x2dcharacters-139.mount
1.353s snap-gnome\x2dcalculator-238.mount
1.333s plymouth-read-write.service
1.311s wpa_supplicant.service
1.275s snap-spotify-21.mount
1.196s snap-spotify-26.mount
1.192s snap-gnome\x2dcalculator-260.mount
1.169s snap-gnome\x2dcalculator-222.mount
1.167s fstrim.service
1.144s apport.service
1.130s fwupd.service
1.130s snap-spotify-24.mount
1.114s snap-gnome\x2dcharacters-124.mount
1.082s systemd-tmpfiles-setup-dev.service
1.024s snap-gnome\x2dlogs-40.mount
1.012s gpu-manager.service
997ms systemd-remount-fs.service
993ms teamviewerd.service
952ms dev-hugepages.mount
950ms sys-kernel-debug.mount
949ms dev-mqueue.mount
937ms snap-gnome\x2dlogs-45.mount
829ms snap-gnome\x2d3\x2d26\x2d1604-70.mount
820ms snap-gtk\x2dcommon\x2dthemes-808.mount
813ms accounts-daemon.service
794ms snap-gnome\x2dcharacters-117.mount
776ms dev-loop6.device
772ms dev-loop1.device
677ms networking.service
670ms snap-gnome\x2dsystem\x2dmonitor-57.mount
647ms systemd-random-seed.service
619ms snap-vlc-555.mount
613ms speech-dispatcher.service
613ms thermald.service
613ms bluetooth.service
610ms systemd-logind.service
608ms avahi-daemon.service
603ms rsyslog.service
590ms pppd-dns.service
577ms packagekit.service
531ms snap-gnome\x2dsystem\x2dmonitor-51.mount
487ms snap-gnome\x2dsystem\x2dmonitor-54.mount
482ms snap-core-5897.mount
471ms kmod-static-nodes.service
422ms colord.service
421ms systemd-journald.service
314ms systemd-tmpfiles-setup.service
312ms console-setup.service
297ms binfmt-support.service
270ms bolt.service
221ms systemd-update-utmp.service
211ms snap-gnome\x2dlogs-43.mount
192ms setvtrgb.service
191ms upower.service
172ms snap-gnome\x2d3\x2d26\x2d1604-74.mount
170ms systemd-timesyncd.service
161ms polkit.service
158ms systemd-resolved.service
124ms systemd-udev-trigger.service
90ms snap-firefox-152.mount
60ms ufw.service
51ms user@1000.service
32ms user@121.service
30ms snapd.seeded.service
8ms systemd-update-utmp-runlevel.service
7ms alsa-restore.service
7ms ureadahead-stop.service
7ms kerneloops.service
6ms rtkit-daemon.service
6ms proc-sys-fs-binfmt_misc.mount
5ms systemd-backlight@backlight:acpi_video0.service
5ms dns-clean.service
2ms systemd-user-sessions.service
2ms sys-fs-fuse-connections.mount
2ms sys-kernel-config.mount
1ms nvidia-persistenced.service
1ms snapd.socket
