If I close the lid on my computer while it's running, it goes into sleep (hibernation?) mode. When I open back it up, the screen wakes up for a moment, then goes black. The computer is unresponsive and I must hard boot o avoid.
I've tried the following solutions. Neither worked:
  1. Edit xorg.conf
  2. Replace gnomescreensaver with xscreensaver
I'm not sure if this is related, but I had issues with the videocard on the laptop during install which I described here:
https://askubuntu.com/a/105792/46766
If you know of a reasonable solution, please share it with a short explanation indicating why you believe it will be effective.
Thanks in advance.
klenwell
  • 4,219
First, start by going to the power cog in the upper-right hand corner of the screen and clicking 'System Settings".
You will see a screen like the following:
Click "Power", then change what happens when you close the lid to something other then "Hibernate".
Hope that helps!
William
  • 7,720
Had problems finding the "power cog" so I entered in the search field, "power" and then selected "change what power options do," then selected "nothing" for "closing the lid."
