Problem: I can't play any sounds.
In Settings -> Sound -> Output there is no device listed.
System: Ubuntu 18.04. This is my laptop, only one user ever connected
Attempts
I've tried lots of forums, threads, ideas, nothing worked.
(1) I've tried
$ aplay -l
returns the devices correctly
(2) I've uninstalled pulseaudio and reinstalled with no success.
(3) To check the groups
$ sudo groups <myuser>
which returns
sudo audio pulse chrome-remote-desktop
(4) If I try to kill it using
$ pulseaudio -k
I get
E: [pulseaudio] main.c: Failed to kill daemon. No such process
(5) IF I try to start pulseaudio
$ pulseaudio --start
then I get
E: [pulseaudio] main.c: Daemon startup failed.
What am I missing? How can I grant the user the access to audio device?
Marius
  • 93
5 Answers5
One thing that helped out is this link: No audio on Ubuntu 18.04 which says to
$ sudo apt-get install pavucontrol
$ pavucontrol
Also I removed then reinstall the pulse audio as
$ sudo apt-get install pulseaudio
With the steps above at least I see my hardware in the Sound settings (output) So it is a step forward. Sound is still muted, but I am working on that.
Marius
  • 93
Check if the service is running:
systemctl --full --all --user status pulseaudio
Make sure to carefully check the output of the command above. You may see a potential cause if you see things like:
Nov 26 12:52:13 pc pulseaudio[2462]: No UCM verb is valid for hw:0
Nov 26 12:52:13 pc pulseaudio[2462]: No UCM verb is valid for hw:2
If that failed to show the cause, start by checking the device and other related info:
sudo lshw -C sound
sudo lspci
alsa-info
sudo fuser -v /dev/snd/*
aplay -l
aplay -lL
sudo apt -y install inxi && inxi -SMA
ls /sys/class/sound  # Check if the card* file numbers match the card* from aplay -l and fuser -v outputs.
You may need to:
systemctl --user enable pulseaudio
export USERI=$(whoami) && sudo addgroup ${USERI} pulse
And you could also consider doing any of these:
sudo alsa force-reload
sudo apt purge alsa-base pulseaudio && sudo apt install alsa-base pulseaudio
Then try reboot.
Upon reinstalling Audacity as a snap this useful tip was displayed:
sudo snap connect audacity:alsa
Worked without rebooting.
This fixed it for me:
systemctl --user restart pulseaudio
Aaron
WHAT HELP TO ME IS:
https://omgubuntu-ru.turbopages.org/turbo/omgubuntu.ru/s/kak-ispravit-otsutstviie-zvuka-v-ubuntu-i-linux-mint/
THAT REALLY HELP ME!!!!!!!!!!!!!!!!!!
mv ~/.config/pulse ~/.config/old_pulse
restart ubuntu
But before i also try:
restart ubuntu
or:
sudo apt-get install --reinstall alsa-base pulseaudio
restart ubuntu
Also, i try this page:
https://dzen.ru/a/ZFZAGBZ7qlOoQkNI
