I made a bootable drive with Etcher on my Mac. I followed the instructions to erase and properly partition the USB flash drive. It is MS-DOS FAT 32 with a GUID partition scheme.
When I try to boot or check for errors I get a black screen as shown below with the errors listed in the title:
[   8.608429] Couldn't get size: 0x800000000000000e
[   8.608453] MODSIGN: Couldn't get UEFI db list
[   8.626775] Couldn't get size: 0x800000000000000e
In that order. I have tried on two different USB drives so far. I made sure to eject the disk when prompted to initialize or eject after Etcher finished installing and validating the ISO. The ISO was downloaded from Ubuntu's page. It is 18.04.1-desktop-amd64.iso I am using a late 2011 Macbook Pro Laptop. Is the ISO possibly the wrong format for my device?
Also when I select the option to boot on restart I get two EFI boot options, both of which do the same thing.
karel
  • 122,292
  • 133
  • 301
  • 332
I had the same issue with:
AMD Athlon 200GE Dual-core MSI B450I Gaming Plus AC
I followed this guide to install Elementary OS, should be the same with Ubuntu
https://elementaryos.stackexchange.com/questions/10000/elementary-os-wont-boot-past-live-cd-screen
Once installed I used the same nomodeset to boot into Elementary OS
Once booted in I updated the kernel to 4.19 using this guide
http://ubuntuhandbook.org/index.php/2018/10/linux-kernel-4-19-released-install-ubuntu/
I had no more issues after that
Use a live usb stick of the same ubuntu version.
Open terminal.
sudo -i
fsck /dev/sdaX
Replace 'X' with your root disk name,and then with all other drives present.
You can check it with fdisk -l.
Reboot. Remove live usb.
It should work now.
