I'm trying to install Ubuntu 18.04 LTS on an Inspiron E1705 PC.
It seems to install correctly (I've tried multiple times on dvd-r and on usb) but when I restart It is doing two things:
  1. It hangs when starting up at the ubuntu screen (the scrolling dots freeze in place) after a minute or so, then the screen turns off completely (not just black but no backlighting or anything) and neither mouse clicks nor button presses do anything. I eventually have to press and hold the power button to get it to turn off.
  2. I ran advanced options for it, but whatever I do it hangs on
    [ OK ] Started Load/Save RF Kill Switches.
    Anyone know whats going on here? I'm trying to do a complete reset and install, it had KODIOS on it before, Windows 10 and Ubuntu before that.
MAJOR EDIT: When I run Ubuntu in recovery mode but just select Resume Normal Boot it works fine. So I can boot into it but only when selecting this option. How can I fix the regular version?
Note: I used the Freeze tag even though it says do not use, because the actualy install is freezing not any installed software. Should I remove it? :P
On some older video hardware configurations, you may need to set kernel parameters for Ubuntu to boot or work properly. A common one is nomodeset, which is needed for some graphics cards (most commonly NVIDIA) that otherwise boot into a black screen or corrupted splash.
To check if you have an Nvidia graphics card:
lspci | grep -i nvidia
or check your video adapter type:
lspci | grep vga
At boot up press Shift or Escape during boot while GRUB is loading to get the menu.
Press E to edit the first kernel displayed. On the line ending with a quiet splash. Add the boot option nomodeset quiet splash
Then press CTRL + X to boot
Lots of further reading links on the net regarding Nvidia and nomodeset.
https://ubuntuforums.org/showthread.php?t=1613132
How do I set 'nomodeset' after I've already installed Ubuntu?
grooveplex
  • 2,506
  • 27
  • 35
Antony
  • 101
