13
I am using Ubuntu 18.04 running GNOME desktop environment
I have two workspaces, one and two, with following windows
  • Work space 1: shell 1, chrome 1
  • Work space 2: shell 2, chrome 2
I want: when I'm in a particular workspace, I can only alt-tab to windows that were opened in that workspace (other windows that were not opened in that workspace should not show up).
I'm aware of some of these related questions:
  1. this one seems like what I am asking here, but the answer was for Unity, not GNOME
  2. The question + answer only make it so that the dock doesn't show windows from other workspaces, I can still alt-tab with it
pomsky
  • 70,557
To ensure that the default task switcher of Gnome Shell (Ubuntu 17.10 and higher) only shows applications of the current workspace, change a setting using the following command:
gsettings set org.gnome.shell.app-switcher current-workspace-only true
You can also change this setting with dconf-editor, a graphical tool that allows inspecting and changing a range of settings of any application that uses the gsettings framework.
To reset to the default setting:
gsettings reset org.gnome.shell.app-switcher current-workspace-only
vanadium
  • 97,564
Alternate Tab extension : https://extensions.gnome.org/extension/15/alternatetab/
Workspace Isolated Dash extension : https://extensions.gnome.org/extension/887/workspace-isolated-dash/ (Isn't work by default with Dash to panel!) or use Dash to panel https://extensions.gnome.org/extension/1160/dash-to-panel/ Settings -> Behavior -> Isolate Workspaces
slava
  • 4,085
