23
Bluetooth not finding any devices in Ubuntu 18.04. I tried different solutions that were found on the internet but with no success.
After Bluetooth is enabled, it keeps searching for devices until it is turned off. All the devices that I am trying to connect with are fully functional, they were paired with other OS and working fine.
Gryu
  • 8,002
  • 37
  • 53
Razvan
  • 361
7 Answers7
34
In my case the BCM43142A0-0a5c-21d7.hcd was missing. Try this command:
dmesg | grep -i 'blue'
If you get:
Bluetooth: hci0: BCM: patch brcm/BCM43142A0-0a5c-21d7.hcd not found
then you have same problem.
Download the BCM43142A0-0a5c-XXXX.hcd file from this GitHub repo; replace XXXX with the exact name that appears in your error message, in this case 21d7, but it could be different for your device.
After that perform:
sudo cp  BCM43142A0-0a5c-21d7.hcd /lib/firmware/brcm/BCM43142A0-0a5c-21d7.hcd
sudo modprobe -r btusb
sudo modprobe btusb
Shut down your PC and restart and it should work.
You might find these answers useful as well:
Ralf
  • 103
Yadnesh Salvi
  • 443
I had this issue too. I tried the suggestions here but none worked for me. My fix was a simple one.
I restart the Bluetooth service using this
sudo service bluetooth restart
I could find and connect to new devices after.
13
These commands may help you:
  1. Install bluez:
    sudo apt-get install bluetooth bluez bluez-tools rfkill
  2. rfkill check and unblock:
    sudo rfkill list
    sudo rfkill unblock bluetooth
  3. Start bluetooth service:
    sudo service bluetooth start
  4. Install bluetooth manager GUI:
    sudo apt-get install blueman
Reference: https://www.youtube.com/watch?v=z-K8IcS_nVw
Whilst Hassan's suggestion did not fully solve my issue, it set me on the path that did solve it.
I don't have rep to post a comment yet, but just wanted to say thank you SO much to Hassan as part of your solution lead me to find a solution for this issue.
It was specifically installing Blueman that helped me solve my issue (whereby my BT headphones stopped connecting after months of working fine).
Whilst Blueman did not solve my issue, it did provide the error:
Connection Failed: blueman.bluez.errors.DBusFailedError: Protocol not available...
On Googling that error, I then did the following and the headphones now connect.
  1. I installed blueman:
  2. Then I ran these commands:
    sudo apt-get install pulseaudio-module-bluetooth
    killall pulseaudio
Then, after restarting Ubuntu, I was able to connect via Blueman.
Owen
The answer posted by Hasan ibrahim didn't work for me. I have a Broadcom Bluetooth and Ubuntu 18.10 operating system. I found out that the firmware was incorrect. So, I download the suitable firmware for my Bluetooth as mentioned in https://askubuntu.com/a/632348/679670 and replaced my Bluetooth firmware with the suitable one. However, my Bluetooth was still not detecting Bluetooth devices.
Then I executed below command from Hassan ibrahim's answer
and restarted my system.
After which my Bluetooth detected other Bluetooth devices.
Jitendra Kumar
  • 101
Answer posted by Yadnesh Salvi pointed me in the right direction to my issue on Ubuntu 18.04.
In my case, i was missing BCM43142A0-0a5c-21d7.hcd and on restart after copying, i found that i am also missing BCM43142A0-105b-e065.hcd.
Followed the same steps as suggested for the missing BCM43142A0-105b-e065.hcd as well and it worked like charm.
I had same problem but it is now solved just download the file and run the command to move this firmware driver for bluetooth. after moving driver file just make a restart your linux pc. https://github.com/winterheart/broadcom-bt-firmware/blob/master/brcm/BCM43142A0-0a5c-21d7.hcd
command :sudo mv downloads/BCM43142A0-0a5c-21d7.hcd/ /lib/firmware/brcm/BCM43142A0-0a5c-21d7.hcd
