11
I would like to turn off the screen saver from command line, which used to work with
gconftool-2 -s /apps/gnome-screensaver/idle_activation_enabled --type=bool false
in natty & oneiric for precise this does not work.
Any ideas?
I know where I can do that in the gui, I'd need the setting for an automatic installation script, that also changes some default settings.
tom
  • 231
7 Answers7
12
these settings will help
gsettings set org.gnome.desktop.screensaver lock-delay 3600
gsettings set org.gnome.desktop.screensaver lock-enabled false
gsettings set org.gnome.desktop.screensaver idle-activation-enabled false
recheck with dconf-editor
when using the gui, these properties will also change in dconf-editor.
tom
  • 231
killall gnome-screensaver ; xset dpms force on
jokerdino
  • 41,732
According to gsettings, this should do the trick:
gsettings set org.gnome.desktop.session idle-delay 0
The command gsettings set org.gnome.desktop.screensaver lock-delay 3600 (delay in seconds) does seem to work for me when reset to 4000. Helps when watching an hours telly on iplayer.
The dconf setting is buried under org/desktop/applications/screensaver.
I think the GUI could be more helpful.
BuZZ-dEE
  • 14,533
john
You will have to employ this command for all users, but after that it will be run and set upon each login. I can't put it in a code box because there are quoted returns in the command that the code box sees as an end. But will be read quite differently by BASH. Copy and paste the following in a terminal and press enter. Do this for each user. It could be incorporates into an install script as well but you will need someone more experienced with making a script run for each user. Copy and paste the whole thing, from echo to the last autostart blank lines and all, one big copy and paste.
echo '#!/bin/bash
sleep 15
xset s 0 0
xset s off
exit 0' > screensave_off.sh ; chmod +x screensave_off.sh ; echo '[Desktop Entry]
Type=Application
Exec= sh ~/screensave_off.sh
Hidden=false
NoDisplay=false
X-GNOME-Autostart-enabled=true
Name=Screen-Saver-Off
Comment=to turn off the Xserver power save' > Screen-Saver-Off.desktop ; chmod +x Screen-Saver-Off.desktop ; mv Screen-Saver-Off.desktop ~/.config/autostart
Wtower
  • 467
dginsd
  • 601
This is what did it for me:
gsettings set org.gnome.desktop.screensaver idle-activation-enabled 0
Eric Carvalho
  • 55,453
For me this worked:
And when I want enable it again
gnome-screensaver &
This is only a temporary solution but if you're looking for it then that's fine.
Aku506
  • 103
