So I was facing some problems when installing a LAMP server a week ago. I couldn't solve them back then and since I didn't have lot of time I quit trying. Now, I tried to install some new software and my mistakes are back to haunt me I can say. Every time I run sudo apt-get I get errors with some mysql relevant lines in the description. For example,here's the output when I run sudo apt-get autoremove:
Reading package lists... Done
Building dependency tree
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
4 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up mysql-common (5.7.21-0ubuntu0.16.04.1) ...
update-alternatives: error: alternative path /etc/mysql/my.cnf.fallback doesn't exist
dpkg: error processing package mysql-common (--configure):
 subprocess installed post-installation script returned error exit status 2
dpkg: dependency problems prevent configuration of mysql-client-5.7:
 mysql-client-5.7 depends on mysql-common (>= 5.5); however:
  Package mysql-common is not configured yet.
dpkg: error processing package mysql-client-5.7 (--configure):
 dependency problems - leaving unconfigured
No apport report written because the error message indicates its a followup error from a previous failure.
        dpkg: dependency problems prevent configuration of mysql-server-5.7:
 mysql-server-5.7 depends on mysql-client-5.7 (>= 5.7.20-0ubuntu0.16.04.1); however:
  Package mysql-client-5.7 is not configured yet.
 mysql-server-5.7 depends on mysql-common (>= 5.6.22-1~); however:
 mysql-server-5.7 depends on mysql-common (>= 5.5); however:
dpkg: error processing package mysql-server-5.7 (--configure):
        dpkg: dependency problems prevent configuration of mysql-server:
 mysql-server depends on mysql-server-5.7; however:
  Package mysql-server-5.7 is not configured yet.
dpkg: error processing package mysql-server (--configure):
No apport report written because MaxReports is reached already
 mysql-common
 mysql-client-5.7
 mysql-server-5.7
 mysql-server
I have searched about this error and most answers were suggesting to use autoremove or install -f(same output). Any help?
cgss
  • 121
