Well, I did a partial upgrade and it included removing gimp. I was planning to reinstall it later, but when I try to, I get the following error:
gimp : Depends: libgimp2.0 (>= 2.7.5) but it is not going to be installed
Depends: libgimp2.0 (<= 2.7.5-z) but it is not going to be installed
Depends: libglib2.0-0 (>= 2.31.2) but 2.30.0-0ubuntu4 is to be installed
Any solution?
Maor
Unless I'm reading that wrong, those versions aren't the default Ubuntu versions. From what I can see, the latest version of Gimp and libgimp in Ubuntu 11.10 is 2.6.11-2. This hints that you have some sort of external repository installed.
Remove that source (The Software Sources program can help out there) and you should be able to install the proper current Ubuntu version.
Edit: your comment shows that there's even more that's been upgraded and now can't be downgraded. To remove a PPA cleanly (and get back to normality) follow this sequence:
  • Install ppa-purge
  • Make sure the PPA/source you were using is active in your sources. If you've already removed it, add it again.
  • Use ppa-purge to nuke the source:
    sudo ppa-purge ppa:repository-name/subdirectory
    (replacing repository-name/subdirectory with the details of the PPA you were using)
More information:
Oli
  • 299,380
You could try to install each dependency or as a "cheat" for me for cases like this I use synaptic. Have a app that gave the same problem, don't remember which. Install synaptic package and from there I install gimp. It solved the dependencies.
You could also try to reinstall it: sudo apt-get install --reinstall gimp. Just in case something was left without uninstalling, the reinstall will pick it up and notice.
Alastair
  • 211
Luis Alvarado
  • 216,643
Maybe it's a obvious suggestion, but have you tried to fix dependencies with
sudo apt-get install -f
? When happened to me, I had sometime to remove all the packages involved one by one, until the dependency error got away. It happened for me on gimp too, the problem was an old libtiff hanging around.
Rmano
  • 32,167
The issue with the ppa's current 2.7.5 build is that when it was built it had a mistake in the /debian/control file concerning libgimp2.0, as in
Depends: ${shlibs:Depends}, ${misc:Depends}, libglib2.0 (>= 2.30.2)
That should have been libglib2.0-0
The end result is the libgimp2.0 has a dual dependency on libglib2.0-0 which is correct & libglib2.0 which is incorrect & cannot be satisfied
This can clearly be seen in the package's control file
Depends: libc6 (>= 2.11), libcairo2 (>= 1.2.4), libgdk-pixbuf2.0-0 (>= 2.22.0),
libglib2.0-0 (>= 2.30.2), libgtk2.0-0 (>= 2.24.0), libpango1.0-0 (>= 1.22.0),
The author has been notified, hopefully he will correct this, you can do yourself but that's beyond the bounds of this question I suspect
doug
  • 17,212
