15
I would like to pin a file's shortcut to the dock in the Ubuntu 18.04 GNOME desktop so that the file opens directly when I click it, for example a spreadsheet file that opens with LibreOffice Calc. Is this possible?
Zanna
  • 72,312
Nick Hope
  • 643
Follow the steps below.
  1. Create a .desktop file (say spreadsheet1.desktop) in ~/.local/share/applications/ directory. You can do that by running the following command in Terminal:
    touch ~/.local/share/applications/spreadsheet1.desktop
  2. Open the file with a text editor, for example by running
    gedit ~/.local/share/applications/spreadsheet1.desktop
    Then add the following lines:
    [Desktop Entry]
    Name=XYZ spreadsheet
    Exec=xdg-open /full/path/to/XYZ-spreadsheet.ods
    Comment=Launch XYZ spreadsheet
    Terminal=false
    Type=Application
    Icon=x-office-spreadsheet
  3. Save the file.
  4. Click on "Activities" or "Show Applications" and search for "XYZ spreadsheet". It should appear.
  5. Right click on it and mark as favourite.
Note: The xdg-open command opens the file with the default application associated with the file-type. You can alternatively set
Exec=libreoffice /full/path/to/XYZ-spreadsheet.ods
in the .desktop file to always open the file with LibreOffice Calc.
pomsky
  • 70,557
To add to the answer from @pomsky, if you want to change the icon, refer to this page.
For example, if you click the icon and the referred url is
https://commons.wikimedia.org/wiki/GNOME_Desktop_icons#/media/File:Gnome-emblem-favorite.svg,
then replace the Icon value with emblem-favorite.
Hiro
  • 153
