Since the original SSD of my Laptop (sdb) is relatively small (100GB) I recently installed another SSD (sda) with a larger capacity (500GB). My idea was to clone the old SSD (sdb) onto the new SSD (sda) with the dd command, therefore I ran the following command from a live-usb-ubuntu-stick:
sudo dd if=/dev/sdb of=/dev/sda bs=64K
in order to copy the contents of sdb (older SSD) onto sda (newer SSD).
After I ran this command, I had difficulties booting from either of the two SSDs (both of which are still installed in the laptop). I then ran the boot-repair command and now GRUB starts normally when I boot from sda. GRUB gives me the following options:
 - Ubuntu
 - Windows 7
 - Ubuntu (on /dev/sda5)
 - Windows 7 (on /dev/sda2)
The problem is that when I want to start the Ubuntu version on the newer SSD (option Ubuntu (on \dev\sda5) in GRUB), GRUB still loads the Ubuntu installation on the old SSD \dev\sdb5.
I think I might need to make manual changes in \boot\grub or to the file \etc\fstab on sda?
\etc\fstab currently has the following contents (on \dev\sda):
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point>   <type>  <options>       <dump>  <pass>
# / was on /dev/sdb5 during installation
UUID=c4055038-09dd-417e-88f1-228ffcf873c1 /               ext4    errors=remount-ro 0       1
# swap was on /dev/sdb6 during installation
UUID=9c79ac5d-78a8-4ab7-9141-8397cb686e25 none            swap    sw              0       0
EDIT:
When I choose Ubuntu (on \dev\sda5) in GRUB and I then run lsblk in a terminal I get the following:
sda      8:0    0 465.8G  0 disk
├─sda1   8:1    0   102M  0 part
├─sda2   8:2    0  78.3G  0 part
├─sda3   8:3    0     1K  0 part
├─sda5   8:5    0 195.8G  0 part
└─sda6   8:6    0   7.9G  0 part
sdb      8:16   0 119.2G  0 disk
├─sdb1   8:17   0   102M  0 part
├─sdb2   8:18   0  78.3G  0 part
├─sdb3   8:19   0     1K  0 part
├─sdb5   8:21   0  31.8G  0 part /
└─sdb6   8:22   0   7.9G  0 part [SWAP]
Mantabit
  • 111
clone-ubuntu.sh Bash Script
Using clone-ubuntu.sh will quickly do what you want. Relevant code snippets to address your problem are included below but visit the link for the complete picture.
Clone like dd
Clone like dd but do it without rebooting into a Live USB. Virtual file systems are automatically skipped to save time and eliminate errors. The script can be rerun if need be (you are testing Ubuntu upgrades/updates for example) and is faster the second time:
rsync -haxAX --stats --delete --info=progress2 --info=name0 --inplace  \
      /* "$TargetMnt"                                                   \
      --exclude={/dev/*,/proc/*,/sys/*,/tmp/*,/run/*,/mnt/*,/media/*,/lost+found}
Update /etc/fstab
Using lsblk to ascertain source and target UUID's the changes are made automatically in the new clone:
# Update /etc/fstab on clone partition with clone's UUID
echo ""
echo "====================================================================="
echo "Making changes in: $TargetMnt/etc/fstab"
echo "        from UUID: $SourceUUID"
echo "          to UUID: $TargetUUID"
sed -i "s/$SourceUUID/$TargetUUID/g" "$TargetMnt"/etc/fstab
Update grub menu with new entries
Grub needs to know the correct UUID's and clone-ubuntu.sh automatically makes them for you:
# Update /boot/grub/grub.cfg on clone partition with clone's UUID
echo ""
echo "Making changes in: $TargetMnt/boot/grub/grub.cfg"
echo "Also change 'quiet splash' to 'nosplash' for environmental awareness"
echo "Suggest first time booting clone you make wallpaper unique"
sed -i "s/$SourceUUID/$TargetUUID/g" "$TargetMnt"/boot/grub/grub.cfg
sed -i "s/quiet splash/nosplash/g" "$TargetMnt"/boot/grub/grub.cfg
Summary
The relevant bash / shell commands are included so you can do the same steps manually for a successful clone that boots and operates as expected.
