I have downloaded the latest Firefox tar.bz2 file and extracted in home directory, I added it in Favorites. But when I launch it shows the older version.
How can I add the latest version in Favorites to launch it directly from the dock?
pomsky
  • 70,557
5 Answers5
For who is having trouble with Firefox Developer Edition, according to this https://askubuntu.com/a/1201328, you have to set the correct StartupWMClass in the .desktop file. My current Firefox Developer version is 98.0b3 and the value for StartupWMClass is firefox-aurora
StartupWMClass=firefox-aurora
Note: shouldn't add quotation in the value of the desktop file
windyzboy
  • 161
Mine which is working fine on Ubuntu 18.04 :
[Desktop Entry]
Name=Firefox Developer
GenericName=Firefox Developer Edition
Exec=/home/sebastien/firefox-dev/firefox %u
Terminal=false
Icon=/home/sebastien/firefox-dev/browser/chrome/icons/default/default128.png
Type=Application
Categories=Application;Network;X-Developer;
Comment=Firefox Developer Edition Web Browser.
StartupWMClass=Firefox Developer Edition
StartupNotify=true
Copy the .desktop file of your new firefox version to .local/share/applications. This will override your system-wide installed firefox.desktop file. Next time you launch firefox, your new firefox.desktop will be in effect. After firefox has loaded, pin it to the dash.
If still your old firefox version is loaded, then probably the .desktop file, on its Exec= line, just calls "firefox" rather than the specific executable of your new version.
If the .tar.gz of your new firefox version does not contain a .desktop file, then copy your system wide firefox.desktop from /usr/share/applications to .local/share/applications.
In both cases, edit the local copy, and change the Exec= line to reflect the actual file path of the executable of your new version. This file path will depend on where you installed this version.
vanadium
  • 97,564
For me changing the NoDisplay from true to false helped in the file ~/.local/share/applications i.e NoDisplay=false
I also added Icon, Terminal, StartupNotify, StartupWMClass
Here is how the file looks now
[Desktop Entry]
Encoding=UTF-8
Version=1.0
Type=Application
NoDisplay=false
Exec=/home/amit/firefox/firefox-bin %u
Name=Firefox
Comment=Custom definition for Firefox
StartupNotify=true
Terminal=false
Icon=/home/amit/firefox/browser/chrome/icons/default/default128.png
Amit JS
Search for firefox .desktop file as below:
ls -lAh ~/.local/share/applications/*.desktop | grep Firefox
mine was: userapp-Firefox Developer Edition-U1OMM2.desktop I added this line as @windyzboy mentioned:
Now it's working perfectly.
