I run Lubuntu 18.04 and I have a problem with the keyboard layout changes. Until recently I used the Greek and the American layout. I now need to write in French for a project so I removed the standard US keyboard layout and I added US, alt.intl. After I did that, each time I try to open a window the default layout (as seen in the panel) become NONE, which I think is the standard US layout. When I switch between my added layout (which should be 2, Greek and US international) they are 3: GR, US and NONE. I tried changing to different international layouts and it does the same. Any ideas? Thank you in advance.
My keyboard doesn't change back to us instead of us intl. It just adds a third layout which is called NONE. I can still switch back to whichever keyboard I want.
