Hi guys I accidentally did an autoremove and somehow my gnome desktop was completely wiped out leaving me with just the shell access to my ubuntu 18.04 - I'm trying to reinstall the ubuntu desktop but it doesn't work and keeps giving me an error.
$ sudo apt-get install ubuntu-desktop
Reading package lists... Done
Building dependency tree
 ubuntu-desktop : Depends: ubuntu-session but it is not going to be installed
                  Recommends: gnome-software-plugin-snap but it is not going to be installed
                  Recommends: libreoffice-pdfimport but it is not going to be installed
                  Recommends: ubuntu-software but it is not going to be installed
I've tried using taskel - just about anything but it gives the same error. I've managed to install kubuntu-desktop using the same command but whats wrong here. I really would want to get my original desktop back. Please help.
Ali
  • 111
Well if you don't have a ton of important files I would back up the important ones and do a fresh install. If you want to try to get the gnome desktop back install this package. It will pull all the needed dependencies. sudo apt install ubuntu-gnome-desktop good luck. If your looking for unity install this sudo apt install ubuntu-unity-desktop
kc1di
  • 382
