Hardware: https://www.asus.com/us/ROG-Republic-Of-Gamers/ROG-G750JS/specifications/
If ubuntu is installed as a dualboot with other distro it want's to use other HDD by default when first HDD has enough space for ubuntu to use and share /boot and swap. -> has to be configured manually
When ubuntu is installed the initramfs-tools fails at the installation and then prevents the system from using apt:
root@Ubuntus-G750JS:/home/kreyonubuntu# apt install fancontrol
Reading package lists... Done
Building dependency tree
fancontrol is already the newest version (1:3.4.0-4).
0 upgraded, 0 newly installed, 0 to remove and 224 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Setting up initramfs-tools (0.130ubuntu3.5) ...
update-initramfs: deferring update (trigger activated)
Processing triggers for initramfs-tools (0.130ubuntu3.5) ...
update-initramfs: Generating /boot/initrd.img-4.15.0-29-generic
gzip: stdout: No space left on device
E: mkinitramfs failure cpio 141 gzip 1
update-initramfs: failed for /boot/initrd.img-4.15.0-29-generic with 1.
dpkg: error processing package initramfs-tools (--configure):
installed initramfs-tools package post-installation script subprocess returned error exit status 1
initramfs-tools
Ubuntu by default is unable to use GPU fan which results in overheating the GPU and possible hardware damage. Same issue on Live version of gentoo.. Related: https://bugs.gentoo.org/669818
If ubuntu is installed as dual-boot it defaults to 4.19.0-gentoo instead of ubuntu kernel. Should be fixed to use ubuntu kernel by default.
Those issues can be reproduced.
EDIT1: If UEFI is used with non-UEFI /boot partition the installation can't switch to non-EUFI version or to reinstall the non-UEFI on UEFI and keep the kernel images.
