After spending so much time to change the settings to make the system work, I want to clone the system so that when something goes wrong, I can recover the system to its last cloned state. What is the best way to do it?
As for regularly backing up files, what is the best way to do so?
Thanks
I would suggest using clonezilla to clone your OS. youo could also use gparted if you prefer see MovingLinuxPartition.
For backups you can use the Ubuntu "backups" tool and set the location you want to back up to I would suggest a different harddrive. you could instead use rsync running in a cron job if you prefer. But I would suggest just using the normal backup tool.
Jeff
  • 1,724
From this answer: Bash script to clone Ubuntu to new partition for testing 18.04 LTS upgrade you can create a working clone that you can boot with new options added to from your menu.
The advantage of cloning this way is you can try new upgrades out on the clone or even intentionally destroy parts of the clone. Then later you can clone your live system again.
It uses incremental copying so only files that are different from the last time cloning was done are copied or deleted.
Tricky issues such as creating new grub menu options or changing UUID's in /etc/fstab are done automatically.
I wouldn't worry about cloning the entire system, just your home directory where all your individual settings are stored. That's what I do. Anyways you will have a built in backup system made for Gnome/Ubuntu. It might not be installed but to do so, install 'deja-dup & duplicity' from your package manager or the console.
SD Allen
  • 129
