The Bluetooth headset problems in Ubuntu are various and mostly not solved profoundly. This time on 18.04 i get a very fast connection with the headset as soon as I turn it on, but the output device does not change automatically to the connected device. Is there any config file which i could change for this purpose??
PS: In another user account on the same PC, I had to restart the bluetooth service everytime i needed to reconnect my device which stayed unsolved until i erased the account and made a fresh one
roxch
  • 253
I had the same problem on Ubuntu 18.04, and I solved it by just copying the file default.pa from /etc/pulse/ into /home/username/.config/pulse/ and it's working.
And now everytime you connect or disconnect the sound output will be changed automatically.
cp /etc/pulse/default.pa /home/username/.config/pulse/
kannzzmm2
  • 1,120
Look for pulse audio volume control in Ubuntu software center. One of them (unfortunately has the same "plated" button icon) has a way to choose how the audio will be consumed and even allow to be send to multiple outputs at the same time. Once installed, open it and if the audio is streamed out through your speakers, you can choose your bluetooth output (once the bluetooth output is conected and paired of course). I know is not the best way, but at least you don't need to do all the dance you have to do to make it work.
George
