I seem to be getting some audio stuttering regardless of which source is playing on 18.04.
I've tried:
- add
options snd-hda-intel position_fix=1to /etc/modprobe.d/alsa-base.conf - edit to
load-module module-udev-detect tsched=1in /etc/pulse/default.pa - add
resample-method = src-sinc-best-qualityin /etc/pulse/daemon.conf
No results whatsoever. A small stutter every 4-5 seconds.
Also, I don't have a wireless card.
Edit:
The audio settings window seems like it changes quickly between 'Line Out - Built-in Audio' and 'Headphones'. Footage here
Edit:
If I connect my headphones through the front panel, the output is stable, but if I connect the same headphones through the audio output on the back, the driver seems to keep switching / disconnecting output channels like shown in the videos.
Both alsamixer and pavucontrol are working nicelly, but they both reflect the fact that output channels seems to keep disappearing for brief moments. (The same thing that happens if I actually connect headphones at the front, but only for a few milliseconds, it's noticable).
I tried disconnecting the whole front panel... thinking that the hardware might be triggering "headphone mode", but it had no effect. It was still switching to headphones for brief stutter-length moments.
Edit: Seems related: link
Edit: Related: Pops/Crackles on Realtek ALC892, HDA Intel PCH (ALSA Though... that topic is closed, and like the last guy, disabling auto mute doesn't solve remove the crackling sound for me either. Does anyone know how to make sure it does? Or what "using only alsa" means?
