I just install Ubuntu 18.04 yesterday, and it seems like Ubuntu cannot detect wifi adapter. The card is working on Windows, so it should not be a problem. I also have the same firmware as the one stated on Intel website (iwlwifi-9260-th-a0-jf-a0-34.ucode). Checking the log, I see iwlwifi failed with error -110.
Any idea how to troubleshoot this issue?
Thanks,
Below is the details log:
$ lspci | grep Network
03:00.0 Network controller: Intel Corporation Device 2526 (rev 29)
$ dmesg | grep iwlwifi
[ 2.536811] iwlwifi 0000:03:00.0: enabling device (0000 -> 0002)
[ 2.570596] iwlwifi: probe of 0000:03:00.0 failed with error -110
[ 382.228750] iwlwifi: probe of 0000:03:00.0 failed with error -110
$ iwconfig
lo no wireless extensions.
eno1 no wireless extensions.
$ modinfo iwlwifi
filename: /lib/modules/4.15.0-29-generic/kernel/drivers/net/wireless/intel/iwlwifi/iwlwifi.ko
license: GPL
author: Copyright(c) 2003- 2015 Intel Corporation <linuxwifi@intel.com>
description: Intel(R) Wireless WiFi driver for Linux
firmware: iwlwifi-100-5.ucode
firmware: iwlwifi-1000-5.ucode
firmware: iwlwifi-135-6.ucode
firmware: iwlwifi-105-6.ucode
firmware: iwlwifi-2030-6.ucode
firmware: iwlwifi-2000-6.ucode
firmware: iwlwifi-5150-2.ucode
firmware: iwlwifi-5000-5.ucode
firmware: iwlwifi-6000g2b-6.ucode
firmware: iwlwifi-6000g2a-6.ucode
firmware: iwlwifi-6050-5.ucode
firmware: iwlwifi-6000-6.ucode
firmware: iwlwifi-7265D-29.ucode
firmware: iwlwifi-7265-17.ucode
firmware: iwlwifi-3168-29.ucode
firmware: iwlwifi-3160-17.ucode
firmware: iwlwifi-7260-17.ucode
firmware: iwlwifi-8265-34.ucode
firmware: iwlwifi-8000C-34.ucode
firmware: iwlwifi-9260-th-b0-jf-b0-34.ucode
firmware: iwlwifi-9260-th-a0-jf-a0-34.ucode
firmware: iwlwifi-9000-pu-a0-jf-b0-34.ucode
firmware: iwlwifi-9000-pu-b0-jf-b0-34.ucode
firmware: iwlwifi-9000-pu-a0-jf-a0-34.ucode
firmware: iwlwifi-QuQnj-a0-hr-a0-34.ucode
firmware: iwlwifi-QuQnj-a0-jf-b0-34.ucode
firmware: iwlwifi-QuQnj-f0-hr-a0-34.ucode
firmware: iwlwifi-Qu-a0-jf-b0-34.ucode
firmware: iwlwifi-Qu-a0-hr-a0-34.ucode
srcversion: 6BA065AF04F0DFDB8D91DBF
depends: cfg80211
retpoline: Y
intree: Y
vermagic: 4.15.0-29-generic SMP mod_unload
signat: PKCS#7
signer:
sig_key:
sig_hashalgo: md4
parm: swcrypto:using crypto in software (default 0 [hardware]) (int)
parm: 11n_disable:disable 11n functionality, bitmap: 1: full, 2: disable agg TX, 4: disable agg RX, 8 enable agg TX (uint)
parm: amsdu_size:amsdu size 0: 12K for multi Rx queue devices, 4K for other devices 1:4K 2:8K 3:12K (default 0) (int)
parm: fw_restart:restart firmware in case of error (default true) (bool)
parm: antenna_coupling:specify antenna coupling in dB (default: 0 dB) (int)
parm: nvm_file:NVM file name (charp)
parm: d0i3_disable:disable d0i3 functionality (default: Y) (bool)
parm: lar_disable:disable LAR functionality (default: N) (bool)
parm: uapsd_disable:disable U-APSD functionality bitmap 1: BSS 2: P2P Client (default: 3) (uint)
parm: bt_coex_active:enable wifi/bt co-exist (default: enable) (bool)
parm: led_mode:0=system default, 1=On(RF On)/Off(RF Off), 2=blinking, 3=Off (default: 0) (int)
parm: power_save:enable WiFi power management (default: disable) (bool)
parm: power_level:default power save level (range from 1 - 5, default: 1) (int)
parm: fw_monitor:firmware monitor - to debug FW (default: false - needs lots of memory) (bool)
parm: d0i3_timeout:Timeout to D0i3 entry when idle (ms) (uint)
parm: disable_11ac:Disable VHT capabilities (default: false) (bool)
UPDATE: I tried to update to kernel 4.18 which use newer firmware but got the same issue.
