I have already installed Russian keyboard layout.
In language support -> installed languages I already have Russian.
But when I open text file with Cyrillic I have encoding problems. This files was created in Windows earlier. With new files I don't have this problem.
Ïðîäâèíóòàÿ ìàìà
Ìàìà ñòðàòåã ñåìåéíûé íàø Åùå óñòðîèò íàì øàáàø Ìû ñ íåé íå óìðåì îò ñêóêè, Çà ýòî öåëóåì åé ðóêè.
UPD. I tried to specify Windows-1251 encoding manually while opening file and Cyrillic has shown correct. I don't have problem in files, which encoding was set as UTF-8.
Usually text files with Russian (Cyrillic) text are created in Windows with Windows-1251 (or CP-1251) encoding. Less often they use ISO 8859-5. While modern systems use UTF-8.
You can always check file encoding with file command:
$ file utf8.txt
utf8.txt: UTF-8 Unicode text
To open files correctly and automatically you can use feature-rich text editor as kate.
Or specify encoding manually when you open file with gedit or other editor.
N0rbert
  • 103,263
