I had asked this question before here. Still having problems, and I don't know where to start. It just froze again, and I shutdown the HP 15 Notebook laptop. I'm now on my old laptop to preserve any logs that were left behind as it was frozen.
I installed Xubuntu 18.04 from a live USB stick, I can boot up with USB, and grab any logs before I restart it from the hard drive if helps. Let me know what you need from me to make this question more answerable. I'm a complete noob, and have read other threads about Xubuntu freezing, but it would be so much easier if someone can point me to the right log that would help diagnose the problem.
I'm able to use my PC sometimes for a few hours, sometimes it will freeze after a few minutes. Usually while I'm browsing the web with Chromium. I have uploaded my syslog to pastebin.com. Hopefully this is what is needed to further help diagnose this problem.
This ACPI BIOS Error bug is found 34 times in the syslog:
Oct  3 01:38:19 PC kernel: [111095.265922] ACPI BIOS Error (bug):
 Failure looking up [\_SB.PCI0.LPCB.EC0._Q33.PMIN], AE_NOT_FOUND (20180313/psargs-330)
Results of inxi -F :
$ inxi -F
System:    Host: PC Kernel: 4.17.0-041700-generic x86_64 bits: 64
           Desktop: Xfce 4.12.3 Distro: Ubuntu 18.04 LTS
Machine:   Device: laptop System: HP product: HP 15 Notebook PC v: Type1 - ProductConfigId serial: N/A
           Mobo: Hewlett-Packard model: 233F v: 06.27 serial: N/A
           UEFI: Insyde v: F.35 date: 04/25/2017
Battery    BAT0: charge: 29.1 Wh 100.0% condition: 29.1/29.1 Wh (100%)
CPU:       Quad core Intel Pentium N3540 (-MCP-) cache: 1024 KB
           clock speeds: max: 2665 MHz 1: 1419 MHz 2: 620 MHz 3: 499 MHz
           4: 499 MHz
Graphics:  Card: Intel Atom Processor Z36xxx/Z37xxx Series Graphics & Display
           Display Server: x11 (X.Org 1.19.6 )
           drivers: modesetting (unloaded: fbdev,vesa)
           Resolution: 1366x768@60.00hz
           OpenGL: renderer: Mesa DRI Intel Bay Trail version: 4.2 Mesa 18.0.5
Audio:     Card Intel Atom Processor Z36xxx/Z37xxx Series High Def. Audio Controller
           driver: snd_hda_intel
           Sound: Advanced Linux Sound Architecture v: k4.17.0-041700-generic
Network:   Card-1: Realtek RTL8188EE Wireless Network Adapter
           driver: rtl8188ee
           IF: wlo1 state: up mac: d4:6a:6a:0f:4d:6c
           Card-2: Realtek RTL8101/2/6E PCIE Fast/Gigabit Ethernet controller
           driver: r8169
           IF: enp3s0 state: down mac: 48:ba:4e:51:23:57
Drives:    HDD Total Size: 500.1GB (30.8% used)
           ID-1: /dev/sda model: WDC_WD5000LPCX size: 500.1GB
Partition: ID-1: / size: 19G used: 5.4G (32%) fs: ext4 dev: /dev/sda6
           ID-2: /home size: 196G used: 131G (71%) fs: ext4 dev: /dev/sda8
           ID-3: swap-1 size: 8.00GB used: 0.00GB (0%)
           fs: swap dev: /dev/sda7
RAID:      No RAID devices: /proc/mdstat, md_mod kernel module present
Sensors:   System Temperatures: cpu: 49.0C mobo: N/A
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 185 Uptime: 11 min Memory: 1060.6/3835.2MB
           Client: Shell (bash) inxi: 2.3.56
After finding the boot log and scrolling through that log, these are the last two entries before the PC froze:
Oct 3 18:07:49 PC systemd-timesyncd[572]: Synchronized to time server 91.189.89.199:123 (ntp.ubuntu.com).
Oct 3 18:09:26 PC systemd-resolved[570]: Using degraded feature set (UDP) for DNS server 192.168.43.1
karel
  • 122,292
  • 133
  • 301
  • 332
I have seen same issues on my Lenovo Thinkpad and a desktop computer. I have found, that baloo service has often high CPU usage and the computer was not responsable ..
So i have disabled baloo with balooctl disable, after restart it works without problems.
roema
  • 31
