In the building where I am living is having a WiFi with two channels and same SSID. Whenever I connect to the WiFi, it always connects to the 2.4GHz band but I want to connect to 5GHz band. I have already tried this but all in vain. Also, I have tried linSSID app but it isn't even launching.
I am using Ubuntu 18.04 LTS and output of lshw -C network:
  *-network
       description: Wireless interface
       product: Wireless 3160
       vendor: Intel Corporation
       physical id: 0
       bus info: pci@0000:01:00.0
       logical name: wlp1s0
       version: 83
       serial: e4:02:9b:d2:65:c7
       width: 64 bits
       clock: 33MHz
       capabilities: bus_master cap_list ethernet physical wireless
       configuration: broadcast=yes driver=iwlwifi driverversion=4.15.0-34-generic firmware=17.948900127.0 ip=172.21.126.136 latency=0 link=yes multicast=yes wireless=IEEE 802.11
       resources: irq:128 memory:df100000-df101fff
Output of iwlist chan:
wlp1s0    26 channels in total; available frequencies :
          Channel 01 : 2.412 GHz
          Channel 02 : 2.417 GHz
          Channel 03 : 2.422 GHz
          Channel 04 : 2.427 GHz
          Channel 05 : 2.432 GHz
          Channel 06 : 2.437 GHz
          Channel 07 : 2.442 GHz
          Channel 08 : 2.447 GHz
          Channel 09 : 2.452 GHz
          Channel 10 : 2.457 GHz
          Channel 11 : 2.462 GHz
          Channel 12 : 2.467 GHz
          Channel 13 : 2.472 GHz
          Channel 36 : 5.18 GHz
          Channel 40 : 5.2 GHz
          Channel 44 : 5.22 GHz
          Channel 48 : 5.24 GHz
          Channel 52 : 5.26 GHz
          Channel 56 : 5.28 GHz
          Channel 60 : 5.3 GHz
          Channel 64 : 5.32 GHz
          Channel 149 : 5.745 GHz
          Channel 153 : 5.765 GHz
          Channel 157 : 5.785 GHz
          Channel 161 : 5.805 GHz
          Channel 165 : 5.825 GHz
muru
  • 207,228
Kulfy
  • 18,154
To confirm that your wireless card is capable of connecting to 5ghz do iw list and look for the portion that looks like below
   Frequencies:
                * 5180 MHz [36] (22.0 dBm) (no IR)
                * 5200 MHz [40] (22.0 dBm) (no IR)
                * 5220 MHz [44] (22.0 dBm) (no IR)
                * 5240 MHz [48] (22.0 dBm) (no IR)
                * 5260 MHz [52] (20.0 dBm) (no IR, radar detection)
                * 5280 MHz [56] (20.0 dBm) (no IR, radar detection)
                * 5300 MHz [60] (20.0 dBm) (no IR, radar detection)
                * 5320 MHz [64] (20.0 dBm) (no IR, radar detection)
                * 5500 MHz [100] (22.0 dBm) (no IR, radar detection)
                * 5520 MHz [104] (22.0 dBm) (no IR, radar detection)
                * 5540 MHz [108] (22.0 dBm) (no IR, radar detection)
                * 5560 MHz [112] (22.0 dBm) (no IR, radar detection)
                * 5580 MHz [116] (22.0 dBm) (no IR, radar detection)
                * 5600 MHz [120] (22.0 dBm) (no IR, radar detection)
                * 5620 MHz [124] (22.0 dBm) (no IR, radar detection)
                * 5640 MHz [128] (22.0 dBm) (no IR, radar detection)
                * 5660 MHz [132] (22.0 dBm) (no IR, radar detection)
                * 5680 MHz [136] (22.0 dBm) (no IR, radar detection)
                * 5700 MHz [140] (22.0 dBm) (no IR, radar detection)
To answer your question, I am assuming the network card is capable of connecting to the 5ghz network. Using the command line interface is flexible compared to using the network manager gui. The important thing is to get the ssid and bssid of the 5ghz network you want to connect to.
sudo systemctl restart wpa_supplicant
sudo wpa_cli -iwlp2s0 scan_results
This would list some values such as
bssid / frequency / signal level / flags / ssid
    54:a2:74:03:c3:a2   2437    -79 [WPA-PSK-CCMP][WPA2-PSK-CCMP][ESS]  \x00
    54:a2:74:03:c3:a0   2437    -79 [WPA2-EAP-CCMP][ESS]    SOME WIFI
    00:42:68:15:f0:92   2437    -90 [WPA-PSK-CCMP][WPA2-PSK-CCMP][ESS]  \x00
    d8:b1:90:3e:e4:62   2412    -79 [WPA-PSK-CCMP][WPA2-PSK-CCMP][ESS]  \x00
    d8:b1:90:3e:e4:6e   5700    -84 [WPA2-EAP-CCMP][ESS]    DESIRED SSID
    54:a2:74:03:c6:a1   2462    -90 [WPA2-EAP-CCMP][ESS]    eduroam
    2a:a3:c4:8d:32:85   2437    -71 [WPA2-PSK-CCMP][WPS][ESS][P2P]  Another SSid
    54:a2:74:03:c6:ae   5500    -89 [WPA2-EAP-CCMP][ESS]    eduroam
    54:a2:74:03:c3:a1   2437    -73 [WPA2-EAP-CCMP][ESS]    eduroam
    00:42:68:15:f0:91   2437    -88 [WPA2-EAP-CCMP][ESS]    eduroam
    d8:b1:90:3e:e4:61   2412    -74 [WPA2-EAP-CCMP][ESS]    eduroam
Look for your desired ssid and the corresponding frequency. Now look for the BSSID that matches the desired frequency and SSID.
Next, kill network-manager and wpa_supplicant:
sudo service network-manager stop && sudo killall wpa_supplicant
This may not be desirable for most people but for the purposes of your question.
Create a wpa_supplicant.conf:
sudo nano /etc/wpa_supplicant.conf
and paste the network specs of the network you are connecting to:
ctrl_interface=/var/run/wpa_supplicant
#settings for an AP using preshared keys, PSK
network={
        ssid="DESIRED SSID"
        scan_ssid=1
        key_mgmt=WPA-PSK
        psk="PassworD"
        bssid=d8:b1:90:3e:e4:6e   #the important part
#settings for an open AP. if you use this then don't use the above settings
network={
        ssid="DESIRED SSID"
        key_mgmt=NONE
Replace bssid with the one of the network you are connecting to
Now start wpa_supplicant via that conf file:
sudo wpa_supplicant -iwlp2s0 -c/etc/wpa_supplicant.conf
After authentication flush any held ip addresses:
sudo dhclient -r
Request a dynamic ip (dhcp):
sudo dhclient wlp2s0
At this point you should be connected to the 5ghz network.
To check whether you are really connected to the 5ghz but not the 2ghz do iw dev and you should have a results like
Interface wlp2s0
    ifindex 2
    wdev 0x1
    addr b4:6d:83:15:9c:5d
    ssid DESIRED SSID
    type managed
    channel 140 (5700 MHz), width: 20 MHz (no HT), center1: 5700 MHz
    txpower 22.00 dBm
The whole procedure above works well but may not survive a reboot and is not useful if you would want to be switching between different kinds of networks.
To start initialize network manage:
sudo service network-manager restart
Then from the network tray icon connect to your DESIRED SSID. Never mind whether it is 2.4 or 5ghz. we would do that later.
Now do:
To get the BSSID that matches the desired frequency and ssid
Next click the network manager tray icon > edit connections > double click on the DESIRED SSID to edit it as following
On wifi tab: SSID (DESIRED SSID), mode (Client), band (5), channel (enter the value you got from the scan results), bssid (enter desired bssid) device (wlp1s0), cloned mac (permanent), mtu (automatic)
Then disconnect and connect again and it should work.
Pablo Bianchi
  • 17,371
ptetteh227
  • 2,044
