At the suggestion of a kind person answering my question I followed the suggestion of going to the following: Here are the title, link and and the terminal output. Still unable to install Kompozer. The Software Updater was run and it reported that the software was up to date.
Kompozer Installation step by step
This was the first line of the code entry and the reply: and it shows the file is already fully retrieved, nothing to do: This was repeated after entering the next lines of code: The errors come later, please look.
    computer@computer-HP-Compaq-8200-Elite-SFF-PC:~$computer@computer-HP-Compaq-8200-Elite-SFF-PC:~$ wget -c https://launchpad.net/ubuntu/+archive/primary/+files/kompozer-dev_0.8~b3.dfsg.1-0.1ubuntu2_all.deb
--2018-10-03 07:31:10--https://launchpad.net/ubuntu/+archive/primary/+files/kompozer-dev_0.8~b3.dfsg.1-0.1ubuntu2_all.deb
Resolving launchpad.net (launchpad.net)... 91.189.89.222, 91.189.89.223
Connecting to launchpad.net (launchpad.net)|91.189.89.222|:443... connected.
HTTP request sent, awaiting response... 303 See Other
Location: https://launchpadlibrarian.net/102977236/kompozer-dev_0.8~b3.dfsg.1-0.1ubuntu2_all.deb [following]
--2018-10-03 07:31:11--  https://launchpadlibrarian.net/102977236/kompozer-dev_0.8~b3.dfsg.1-0.1ubuntu2_all.deb
Resolving launchpadlibrarian.net (launchpadlibrarian.net)... 91.189.89.229, 91.189.89.228
Connecting to launchpadlibrarian.net (launchpadlibrarian.net)|91.189.89.229|:443... connected.
HTTP request sent, awaiting response... 200 OK
The file is already fully retrieved; nothing to do.
The last two code entries reported error, here is one of them.
computer@computer-HP-Compaq-8200-Elite-SFF-PC:~$ sudo dpkg -i kompozer*.deb
dpkg: error processing archive kompozer_0.8~b3.dfsg.1-0.1ubuntu2_amd64.deb (--install):
 package architecture (amd64) does not match system (i386)
(Reading database ... 213540 files and directories currently installed.)
Preparing to unpack kompozer-data_0.8~b3.dfsg.1-0.1ubuntu2_all.deb ...
Unpacking kompozer-data (1:0.8~b3.dfsg.1-0.1ubuntu2) over (1:0.8~b3.dfsg.1-0.1ubuntu2) ...
Selecting previously unselected package kompozer-dev.
Preparing to unpack kompozer-dev_0.8~b3.dfsg.1-0.1ubuntu2_all.deb ...
Unpacking kompozer-dev (1:0.8~b3.dfsg.1-0.1ubuntu2) ...
Setting up kompozer-data (1:0.8~b3.dfsg.1-0.1ubuntu2) ...
dpkg: dependency problems prevent configuration of kompozer-dev: kompozer-dev depends on kompozer (>= 1:0.8~b3.dfsg.1-0.1ubuntu2).dpkg: error processing package kompozer-dev (--install):dependency problems - leaving unconfigured
Processing triggers for man-db (2.7.5-1) ...Errors were encountered while processing:kompozer_0.8~b3.dfsg.1-0.1ubuntu2_amd64.deb kompozer-dev
I would appreciate help: All I know is to follow the examples that I can find here. Thank You (October 3, 2016)
Listed below are the previous attempts to install KompoZer. The newest attempt of Oct 3, 2018 is listed above. Trying to install KompoZer on 18.04.1 and 16.04.4 following suggestions from askUbuntu: First downloaded and extracted kompozer-0.8b3.lt.gcc4-2-686.tar.gz. from SourceForge. Now needed to know how to install the extracted files. Here are: Link Question Answer and the Unsucessful terminal output On how to install kompozer on ubuntu after downloading How to install kompozer on xubuntu after downloading 1 Answer If you googled, you would have got this in first place. Any way here you go.
    sudo apt-get install libatk1.0-0 libc6 libcairo2 libfontconfig1   libfreetype6 libgdk-pixbuf2.0-0 libglib2.0-0 libgtk2.0-0  libidl0 libnspr4 libnss3 libpango1.0-0 libpng12-0 libstdc++6 libx11-6 libxft2 libxinerama1 libxrender1 libxt6 zlib
And the unsucessful terminal output:
[sudo] password for computer:
Reading package lists... Done
Building dependency tree
Package libidl0 is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
However the following packages replace it:  libidl-2-0
Package zlib1 is not available, but is referred to by another package.
E: Package 'libidl0' has no installation candidate
E: Package 'zlib1' has no installation candidate
Here is another trial with askUbuntu: Link, Question, Answer and Unsuccessful terminal output
Unable to install Kompozer in Ubuntu 16.04 For briefity only the last lines of code shown, no errors returned on previous lines, but the last four lines gave errors and for briefity just one of them will be shown, more can be given 64-Bit:
sudo dpkg -i libidl0_0.8.14-1_amd64.deb
sudo dpkg -i libpng12-0_1.2.54-1ubuntu1_amd64.deb
sudo dpkg -i kompozer-data_0.8~b3.dfsg.1-0.1ubuntu2_all.deb
sudo dpkg -i kompozer_0.8~b3.dfsg.1-0.1ubuntu2_amd64.deb
The terminal input/output entering the first sudo command these errors are encountered
dpkg: error processing archive libidl0_0.8.14-1_amd64.deb (--install):
And to be sure this is a 64 bit program and a 64 bit machine: I would appreciate any help. Thank you
Thank you: I have poured over the link although I can't see how to use its content: Listed are every command I see.
sudo dpkg --configure -a
foo@foo:~$ sudo apt-get install -f
dpkg --get-selections | grep hold
sudo aptitude install <packagename>
sudo aptitude -f install <packagename>
sudo apt-get autoremove
I want to assured you I have looked at every line: 3rd through 5th are unfamilar to me and I don't understand how they may fix a broken package. Thank you
Thomas Ward
  • 78,878
It looks like you tried to run an incorrect command that looks like this:
sudo apt install libx Unable to install Kompozer in Ubuntu 3 11-6
Instead of running a command that looks like this:
sudo apt install libx11-6
Somehow or another you accidentally pasted the string Unable to install Kompozer in Ubuntu 3 in the middle of the command, so let's start over from the beginning and run the following commands in Ubuntu 18.04. For Ubuntu 16.04 go back to the same link that you mentioned in your question, and follow the instructions for installing KompoZer in 16.04 instead of 18.04.
sudo apt install libatk1.0-0 libc6 libcairo2 libfontconfig1 libfreetype6 libgdk-pixbuf2.0-0 libglib2.0-0 libgtk2.0-0 libnspr4 libnss3 libpango1.0-0 libstdc++6 libx11-6 libxft2 libxinerama1 libxrender1 libxt6 zlib1g
wget https://launchpad.net/ubuntu/+archive/primary/+files/kompozer-data_0.8%7Eb3.dfsg.1-0.1ubuntu2_all.deb
wget https://launchpad.net/ubuntu/+archive/primary/+files/kompozer_0.8%7Eb3.dfsg.1-0.1ubuntu2_amd64.deb
wget https://launchpad.net/ubuntu/+archive/primary/+files/libidl0_0.8.14-1_amd64.deb
wget https://launchpad.net/ubuntu/+archive/primary/+files/libpng12-0_1.2.54-1ubuntu1_amd64.deb
sudo apt install ./libidl0_0.8.14-1_amd64.deb
sudo apt install ./libpng12-0_1.2.54-1ubuntu1_amd64.deb
sudo apt install ./kompozer-data_0.8~b3.dfsg.1-0.1ubuntu2_all.deb
sudo apt install ./kompozer_0.8~b3.dfsg.1-0.1ubuntu2_amd64.deb
Note that first you need to download libidl0_0.8.14-1_amd64.deb with wget before you can install it with sudo apt-get install ./package.deb
To start KompoZer, open the terminal and run kompozer.
Update
kompozer is a native snap package in all currently supported versions of Ubuntu. This snap package preserves the last available version of KompoZer from 2010, and allows KompoZer to be used on modern operating systems. KompoZer can be installed from the Software app or from the terminal with the following command:
sudo snap install kompozer
karel
  • 122,292
  • 133
  • 301
  • 332
