I'm testing Ubuntu 18.04 with my current desktopand everything works correctly except for the Wi-Fi adapter. I'm using a TP-LINK TL-WN8200ND version 2.
As requested here, my wireless-info output is at this pastebin.
I've tested Mint 19, Kubuntu and KDE neon, with similar results.
Is there an official driver that works out of the box?
amyspark
  • 111
5 Answers5
For newer kernels (>=5) you could use the driver from https://github.com/clnhub/rtl8192eu-linux
I tried with success from Ubuntu 19.04:beta (kernel 5.0.0-7-generic)
First, install kernel-headers, build-essentials, git, binutils and dkms packages.
sudo apt install -y linux-headers-$(uname -r) build-essential git binutils dkms
Finally, download the driver and install as root
sudo bash
cd /tmp
git clone https://github.com/clnhub/rtl8192eu-linux.git
cd rtl8192eu-linux/
./install_wifi.sh
On Ubuntu 20.04 this should work for TL-WN8200ND.
Using the terminal, type the commands below:
sudo apt update;
sudo apt-get install git linux-headers-generic build-essential dkms;
git clone https://github.com/Mange/rtl8192eu-linux-driver;
cd rtl8192eu-linux-driver;
sudo dkms add .;
sudo dkms install rtl8192eu/1.0;
echo "blacklist rtl8xxxu" | sudo tee /etc/modprobe.d/rtl8xxxu.conf;
echo -e "8192eu\n\nloop" | sudo tee /etc/modules;
echo "options 8192eu rtw_power_mgnt=0 rtw_enusbss=0" | sudo tee /etc/modprobe.d/8192eu.conf;
sudo update-grub; sudo update-initramfs -u;
systemctl reboot -i;
Source: https://github.com/Mange/rtl8192eu-linux-driver
Adapter image:
Pizza
  • 1,512
ISRAEL
With a working internet connection by ethernet, tethering or whatever means possible, open a terminal and do:
sudo apt-get update
sudo apt-get install build-essential dkms git
git clone https://github.com/luckynzm/tlwn8200nddriver.git
cd tlwn8200nddriver
sudo dkms add .
This will take some time; please be patient.
Next, blacklist the built in driver that isn’t working:
sudo -i
echo “blacklist rtl8xxxu”  >>  /etc/modprobe.d/blacklist.conf
exit
Reboot. Your wireless should be working.
chili555
  • 61,330
I have been trying to make it work for the last couple of weeks, and finally I found a driver that works.
I am using Ubuntu 18.04, kernel 4.15.0-46. Check yours with
uname -a
What did work
From https://ubuntuforums.org/showthread.php?t=2340202
sudo apt-get install linux-headers-generic git build-essential
linux-driver.git
make
sudo make install
reboot
It also says that if the kernel is updated do: (so keep the directory)
make clean
make
sudo make install
Testing connection
The first thing to notice is that the led is going green. On the top right click on wifi symbol and the network must appear (my internal adapter and the USB adapter in my case). You can connect to a wifi network here. You can also check your adapters with:
iwconfig
You can also check it with:
lshw -short
Unplug it and run the command again to see which one was the usb adapter.
You can also create a hostpot, ad-hoc or station mode network with the command:
nm-connection-editor
Just as in Ubuntu 16.04.
What didn't work for me
I tried this drivers without success:
I also tried to downgrade the kernel version (to try these drivers to run without success) to:
  • 4.9.8
  • 4.8.10 (ubuntu 18.04 didn't boot)
  • 3.12.74 (ubuntu 18.04 didn't boot)
Simple way to activate TP-LINK WN8200ND
on UBUNTU 22.04 or Debian 11 (Debian without sudo), open terminal and =
sudo apt update
sudo apt install build-essential dkms git
cd rtl8192eu-linux/
./install_wifi.sh
ISRAEL
  • 89
