So, inside my C: drive are Windows files and also inside it are an Android OS called “Android x86”. I dual-boot these two OS using a boot loader called Grub that came with Android x86. The Android x86 OS files are located inside my C: drive and in the same partition of Windows. If you look in a file explorer in the C: drive are the Windows 10 files and also a folder named android-8.1-rc1 which is where Android is located.
I have 2 questions:
Can I install Ubuntu inside the same partition Windows is installed without wiping the partition or drive, like I could do when installing Android x86?
Can I multi-boot Windows, Android, and Ubuntu using the Grub boot loader that came with Android x86? Like is there some command I have to type in to add Ubuntu to the list of OS to select when booting?
