I tried those two command and get some error:
  1. sudo add-apt-repository ppa:flexiondotorg/albert
    An amazing, desktop environment agnostic, omnilauncher.
    https://github.com/ManuelSchneid3r/albert
     More info: https://launchpad.net/~flexiondotorg/+archive/ubuntu/albert
    Press [ENTER] to continue or Ctrl-c to cancel adding it.
    Ign:1 http://dl.google.com/linux/chrome/deb stable InRelease
    Hit:2 http://dl.google.com/linux/chrome/deb stable Release
    Hit:4 http://mirror.dhakacom.com/ubuntu-archive bionic InRelease
    Get:5 http://mirror.dhakacom.com/ubuntu-archive bionic-updates InRelease [88.7 kB]
    Ign:6 http://ppa.launchpad.net/flexiondotorg/albert/ubuntu bionic InRelease
    Get:7 http://mirror.dhakacom.com/ubuntu-archive bionic-backports InRelease [74.6 kB]
    Get:8 http://mirror.dhakacom.com/ubuntu-archive bionic-security InRelease [83.2 kB]
    Hit:9 http://ppa.launchpad.net/noobslab/apps/ubuntu bionic InRelease
    Hit:10 http://ppa.launchpad.net/notepadqq-team/notepadqq/ubuntu bionic InRelease
    Err:11 http://ppa.launchpad.net/flexiondotorg/albert/ubuntu bionic Release
      404  Not Found [IP: 91.189.95.83 80]
    Hit:12 http://archive.canonical.com/ubuntu bionic InRelease
    Reading package lists... Done
    E: The repository 'http://ppa.launchpad.net/flexiondotorg/albert/ubuntu bionic Release' does not have a Release file.
    N: Updating from such a repository can't be done securely, and is therefore disabled by default.
    N: See apt-secure(8) manpage for repository creation and user configuration details.
  2. sudo apt-get update && sudo apt-get install albert
    Hit:1 http://mirror.dhakacom.com/ubuntu-archive bionic InRelease
    Get:2 http://mirror.dhakacom.com/ubuntu-archive bionic-updates InRelease [88.7 kB]
    Get:3 http://mirror.dhakacom.com/ubuntu-archive bionic-backports InRelease [74.6 kB]
    Get:4 http://mirror.dhakacom.com/ubuntu-archive bionic-security InRelease [83.2 kB]
    Ign:5 http://dl.google.com/linux/chrome/deb stable InRelease
    Hit:6 http://archive.canonical.com/ubuntu bionic InRelease
    Hit:7 http://dl.google.com/linux/chrome/deb stable Release
    Ign:9 http://ppa.launchpad.net/flexiondotorg/albert/ubuntu bionic InRelease
    Hit:10 http://ppa.launchpad.net/noobslab/apps/ubuntu bionic InRelease
    Hit:11 http://ppa.launchpad.net/notepadqq-team/notepadqq/ubuntu bionic InRelease
    Err:12 http://ppa.launchpad.net/flexiondotorg/albert/ubuntu bionic Release
Pablo Bianchi
  • 17,371
Abu
  • 165
Albert is my favorite quick launcher, so I have it installed in Ubuntu 18.04. The errors you are getting appear to reflect temporary or perhaps permanent problems with the PPA.
Installing through PPA
The User guide of Albert refers for more instructions to a site of openSUSE. There, you click on the Ubuntu icon. You will find instructions there to connect to a PPA that is different than the one you attempted.
Installing through a .deb installation file
I prefer to install Albert by downloading a .deb installation file. The advantage is that you do not need to add an external PPA. The drawback is that the program will not automatically be updated as new versions appear. Depending on how you see it, this might actually be an advantage. Albert is in strong development, and a new version may sometimes have issues.
The second link on the page, "Grab binary packages directly", allows you to download 64 bit or 32 bit .deb installation files.. Right-click the downloaded .deb and select "Open with software installer". This will install the .deb file using Ubuntu software.
vanadium
  • 97,564
Here are some more detailed instructions on how to install albert using the suse repository.
Before you begin, you will need to enable the Universe repository. Click here for more info.
There are two ways to install albert.
Method 1 (grab binary packages directly):
Run the following command to install gdebi which will be used to install albert:
sudo apt update
sudo apt install gdebi
Run the following commands to download and install the 64 bit version of albert for 18.04:
wget https://download.opensuse.org/repositories/home:/manuelschneid3r/xUbuntu_18.04/amd64/albert_0.16.1_amd64.deb
sudo gdebi albert_0.16.1_amd64.deb
Method 2 (add repository and install manually):
This method installs a trusted key to your system. Click here for more info.
curl -fsSL https://download.opensuse.org/repositories/home:manuelschneid3r/xUbuntu_18.04/Release.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/home_manuelschneid3r.gpg > /dev/null
sudo sh -c "echo 'deb http://download.opensuse.org/repositories/home:/manuelschneid3r/xUbuntu_18.04/ /' > /etc/apt/sources.list.d/home:manuelschneid3r.list"
sudo apt update
sudo apt install albert
To install for any other version of Ubuntu, replace the version number 18.04 in the above commands with your version (currently from 16.04 to 22.10).
Additionally, to delete the repository and the trusted key, run the following commands:
sudo rm /etc/apt/sources.list.d/home:manuelschneid3r.list
sudo apt-key del E192A257
sudo apt clean
sudo apt update
Artur Meinild
  • 31,035
mchid
  • 44,904
  • 102
  • 162
There is no package of Albert released in the ppa:flexiondotorg/albert for 18.04 LTS, but you can download the 17.10 package manually and install it:
wget http://ppa.launchpad.net/flexiondotorg/albert/ubuntu/pool/main/a/albert/albert_0.11.1-1~ppa1.0_amd64.deb
sudo apt install ./albert_0.11.1-1~ppa1.0_amd64.deb
Note: I have wrote message to @flexiondotorg to get package for 18.04 LTS in near future.
N0rbert
  • 103,263
