Should I use dd or similar before I use testdisk? I reformatted an ntfs partition and would like to recover some of the data. I am using live ubuntu. Also is testdisk good for this type of job? Thank you in advance.
My question is different from this because that doesn't say if you should clone the drive before using testdisk.
zxxz135
and welcome to Stack Overflow. I hope we don't take up too much of your time.
As for your issue - this is just a recommendation, and this is purely based on my opinion: gddrescue or GNU ddrescue (ddrescue). It clones items, but with a -v or -vv it gives good indications about where it is in the recovery process and is very configurable in its options (such as bad skip amount, read direction, direct v. indirect reading, and things of that nature).
Before I can give you the command line to use it, I need to know:
  1. Were you planning on backing up the item to another physical disk (/dev/sdc) or as an image on a filesystem?
  2. Are you backing up the whole disk as an image? (e.g. /dev/sda )
  3. If 1 & 2 , Are you familiar with using loop + offsets to mount a partition in the whole disk image?
  4. If you are doing a straight copy, I'll assume that the target is larger than the destination, right? There's some oddness with the way that certain manufacturer's label disk sizes, so keep that in mind (GB = 1000^3 instead of GiB 1024^3 - GiB are bigger)
I'll update this as you get back with me, as the recommendations I give will be based on what you tell me. Even if you were using just dd, the top 4 questions would still apply.
Be aware that dd is sometimes referred to as "destructively duplicate" or "dangerously duplicate", and ddrescue is derived from dd. If you confuse input and output, it is possible to completely destroy what you are trying to save.
Be careful!
edit 1:
If you believe that the partition was deleted or has some otherwise user-injected corruption, rather than device injected, the safe route is to duplicate the device first. Then duplicate the duplicate. Then run your tests on the third generation copy, whether it be testdisk for partition recovery/repair, or photorec to recover lost photos from the partition. That way, if things are hopelessly scrambled, you can just go back a generation and duplicate that and try again. I recommend refraining from running testdisk on the master copy (unless one of the copies responded positively to your probes, and you could verify the items enclosed weren't corrupted).
If the partition was BitLocker or LUKS encrypted, you may have an uphill battle in front of you. Best of luck.
The Dude
  • 404
