I can run redshift from a command line, but can't get it working in systemd. The steps in a similar question didn't do the trick for me.
Ubuntu 16.04.
My redshift.service:
$ cat /etc/systemd/system/redshift.service
[Unit]
Description=restrict blue light
After=graphical.target
[Service]
ExecStart=/usr/bin/redshift -v
Environment=DISPLAY=:0
[Install]
WantedBy=graphical.target
If I run /usr/bin/redshift from the command line it starts recoloring my screen. If I try to start the service it dumps:
$ sudo systemctl status redshift
● redshift.service - restrict blue light
   Loaded: loaded (/etc/systemd/system/redshift.service; enabled; vendor preset: enabled)
   Active: failed (Result: exit-code) since Sun 2018-09-16 21:23:51 PDT; 4s ago
  Process: 4676 ExecStart=/usr/bin/redshift -v -l 37.35:121.99 (code=exited, status=1/FAILURE)
 Main PID: 4676 (code=exited, status=1/FAILURE)
Sep 16 21:23:51 cyberpower-linux redshift[4676]: Initialization of randr failed.
Sep 16 21:23:51 cyberpower-linux redshift[4676]: Trying next method...
Sep 16 21:23:51 cyberpower-linux redshift[4676]: No protocol specified
Sep 16 21:23:51 cyberpower-linux redshift[4676]: X request failed: XOpenDisplay
Sep 16 21:23:51 cyberpower-linux redshift[4676]: Initialization of vidmode failed.
Sep 16 21:23:51 cyberpower-linux redshift[4676]: No more methods to try.
Sep 16 21:23:51 cyberpower-linux systemd[1]: redshift.service: Main process exited, code=exited, status=1/FAILURE
Sep 16 21:23:51 cyberpower-linux systemd[1]: redshift.service: Unit entered failed state.
Sep 16 21:23:51 cyberpower-linux systemd[1]: redshift.service: Failed with result 'exit-code'.
If I run xhost + and try to start again, it does start coloring the screen. How can I give my systemd script access to my window server without giving everything access to my window server?
Thanks in advance for any clues...
megabob
An update: after moving the service from /etc/systemd/system/redshift.service to ~/.config/systemd/user/redshift.servce, it started working.
Note that /etc/systemd/user/redshift.service didn't work!
I'd still welcome an answer showing me how to install this for all users of this host.
megabob
Keep restarting it and it will finally work lol. The problem might be that, before logging in, gdm has not yet started Xorg and thus there is no display but I am not sure. I would try having gdm started first as a requirement and see what happens.
[Unit]
After=multi-user.target
StartLimitIntervalSec=0
[Service]
Type=simple
ExecStart=/usr/bin/redshift -O 3000
Restart=always
RuntimeMaxSec=60
[Install]
tinlyx
  • 3,328
