Context: My laptop's battery died. Upon resetting the machine, the audio did not work. I tried to kill pulseaudio and use commands from Ask Ubuntu, but these methods did not fix the issue. I then uninstalled pulseaudio, and tried to re-install it, which returned the following error:
Reading package lists... Done
Building dependency tree
pulseaudio : Depends: libpulse0 (= 1:8.0-0ubuntu3) but 1:8.0-0ubuntu3.7 is to be installed
Depends: pulseaudio-utils but it is not going to be installed
Recommends: pulseaudio-module-x11 but it is not going to be installed
Given that I got into this weird system state by randomly typing in commands, I wanted to figure out a "first-principles" approach to solving this issue. What should be my first attempt here?
