tio@tio:~$ sudo apt install vlc
[sudo] password for tio:
Reading package lists... Done
Building dependency tree
 vlc : Depends: vlc-bin (= 3.0.1-3build1) but it is not going to be installed
       Depends: vlc-plugin-base (= 3.0.1-3build1) but 3.0.2-0ubuntu0.1 is to be installed
       Depends: vlc-plugin-video-output (= 3.0.1-3build1) but 3.0.2-0ubuntu0.1 is to be installed
       Recommends: vlc-l10n (= 3.0.1-3build1) but it is not going to be installed
       Recommends: vlc-plugin-notify (= 3.0.1-3build1) but it is not going to be installed
       Recommends: vlc-plugin-samba (= 3.0.1-3build1) but it is not going to be installed
       Recommends: vlc-plugin-skins2 (= 3.0.1-3build1) but it is not going to be installed
       Recommends: vlc-plugin-video-splitter (= 3.0.1-3build1) but it is not going to be installed
       Recommends: vlc-plugin-visualization (= 3.0.1-3build1) but it is not going to be installed
tio@tio:~$
I have Ubuntu 18.04 with main and universe repos active.
tio@tio:~$ apt-cache policy vlc vlc-bin vlc-plugin-base vlc-plugin-video-output
vlc:
  Installed: (none)
  Candidate: 3.0.1-3build1
  Version table:
     3.0.1-3build1 500
        500 http://archive.ubuntu.com/ubuntu bionic/universe amd64 Packages
vlc-bin:
  Installed: (none)
  Version table:
     3.0.1-3build1 500
vlc-plugin-base:
  Installed: 3.0.2-0ubuntu0.1
  Candidate: 3.0.2-0ubuntu0.1
  Version table:
 *** 3.0.2-0ubuntu0.1 100
        100 /var/lib/dpkg/status
     3.0.1-3build1 500
vlc-plugin-video-output:
  Version table:
     3.0.1-3build1 500
tio@tio:~$
Tio TROM
  • 663
With the help of the answers from here I fixed it this way:
  1. sudo apt remove vlc*
  2. sudo apt autoclean
  3. sudo apt autoremove
  4. sudo apt install vlc*
Thank you very much people!
N0rbert
  • 103,263
Tio TROM
  • 663
I had the same issues with installing VLC in Ubuntu on Cosmic i386. I could not resolve the "unmet dependencies" due to "broken packages being held";
Running Terminal: sudo synaptic (It did not reveal any broken packages).
Double check your Ubuntu version that main and universe repos are active.
Terminal Input: sudo apt install vlc revealed the following:
vlc : Depends: vlc-bin (= 3.0.4-2build1)
      Depends: vlc-plugin-base (= 3.0.4-2build1)
      Depends: vlc-plugin-video-output (= 3.0.4-2build1)
      Recommends:vlc-l10n (= 3.0.4-2build1)
      Recommends: vlc-plugin-notify (= 3.0.4-2build)
      Recommends: vlc-plugin-samba (= 3.0.4-2build1)
      Recommends: vlc-plugin-skins2 (= 3.0.4-2build1)
      Recommends: vlc-plugin-video-splitter (= 3.0.4-2build1)
      Recommends: vlc-plugin-visualization (= 3.0.4-2build1)
To solve this, I ran:
sudo apt clean
sudo apt autoclean
sudo apt autoremove
sudo apt update
sudo apt upgrade
I ran a downgrade for all of the above dependencies, for example
sudo apt install vlc-plugin-base=3.0.4-2build1 (or your specific build number)
Do this for each dependency and then run;
sudo apt install vlc* [**The asterisk is the key!**]
Any remaining missing dependencies will be revealed and you can then downgrade additional residual dependencies and install VLC with all its recommended packages.
Hope this helps someone it took me a week to work this one out.
zx485
  • 2,865
Bigg Ruggs
These commands should do the work.
sudo apt clean
sudo apt autoclean
sudo apt autoremove
sudo apt update
sudo apt upgrade
pandafy
  • 326
