I'm using Ubuntu 18.04 on GNOME. When I try to lock my screen, nothing happens. Going into my Privacy settings won't let me enable the Lock Screen. Is this an issue regarding permissions?
vanadium
  • 97,564
Try the default lock screen (screen lock) key combination on Ubuntu 18.04 and Fedora 28 first:
  • Super+L (that is Windows+L). On terminal try xdg-screensaver lock.
  • If that did not work then check whether the following command returns true:
     gsettings get org.gnome.desktop.lockdown disable-lock-screen
  • If the command above returned true then do the following:
     gsettings set org.gnome.desktop.lockdown disable-lock-screen false
Check whether the lock screen (screen lock) works now.
Had a similar problem and this helped me solve my issue.
Pablo Bianchi
  • 17,371
Here's one thing you can try.
  1. First of all, make sure gnome-screensaver is installed
    sudo apt install gnome-screensaver
  2. Try to issue lock command in the terminal:
    gnome-screensaver-command -l
    then see if there's any text output in the terminal, such as "Screensaver is not running!"
    If it's the case, run the daemon:
    gnome-screensaver &
    then retry the previous lock command. Let's hope it will work now.
Lilly-R B
  • 448
