Does the card Asus PCE-AC88 work out of the box on Ubuntu 18.04 ?
There are some informations about its compatibility with Ubuntu, for example here:
Installing Broadcom Wireless Drivers
or there:
https://blog.cooperteam.net/post/2017-11-10-asus-ac88-wifi-on-linux/
but I could not find anything about the status of its compatibility with Ubuntu 18.04.
I would like to know before I buy the card.
Henry
  • 654
If it helps I can safely say this has been fixed with the latest 5.0 kernel. So all Ubuntu derivatives of 19.04 will work out of the box. I say this posting with Pop!_os 19.04 (and before that I installed Ubuntu 19.04 and Ubuntu Budgie 19.04 and they all work out the box). So pleased this is finally fixed.
Edit: ... and yes it's going at high speeds, can't test on a several hundred Mbps download/upload any more but my current internet is 70 down and 20 up and its maxing out flawlessly.
I just installed that card on Ubuntu 18.04 but it does not work out of the box. Found this related discussion with a documentation how to solve the problem: https://ubuntuforums.org/showthread.php?t=2337200
Certainly not an easy solution to apply. Will try it during the next days.
UPDATE:
Got the card working with the help of this blog entry: https://blog.cooperteam.net/post/2017-11-10-asus-ac88-wifi-on-linux/ It already contains the patched driver for the card ready to download: https://blog.cooperteam.net/brcmfmac4366c-pcie.bin
I moved the file to to my drivers:
sudo mv brcmfmac4366c-pcie.bin /lib/firmware/brcm
Rebooted - works.
UPDATE:
Drivers are so slow (slower than any cheap Wifi card) that I gave up, sold the card, and switched to Powerline.
As James Reid says:
Now we have Ubuntu 18.04.3 with 5.0.0-31 kernel. Just run:
sudo apt-get update && sudo apt-get dist-upgrade -y
to get the last kernel version.
Dennis V
  • 151
The card "works" under Linux using those drivers linked above, but only at its slowest speed. I used the same PC with Windows and Linux, with this WiFi adapter, and saw download speeds of 388Mbps under Windows from my Virgin Media hub, and just 1.6Mbps under Linux (Ubuntu 18.04). It is not worth using this card with Linux, as you'll get faster speeds from a much cheaper, but better supported chipset currently.
